Technics SU-Z2 tension de 35V en la salida de bocina del Amp
Error message
The comment you are replying to does not exist.
Cambiamos el CI  STK 2038 y sigue el problema.
Hay tensión continua +35V en la salida de bocina en Amplificador SU Z2 Technics.
Gracias
torokj
torokj picture
Hello,
https://elektrotanya.com/technics_su-z2_sch_2.pdf/download.html
DId you check the -35 V negative voltage on the pin 4 of the SVISTK 2038?Also check the feedback resistors (R329-332)
If the simmetrical power supply voltages are OK (+35V pin 2,-35V pin 4, you propably  bought a FAKE power amp hybrid IC.
TJ
