Hi!
You will need a transformer that supplies 2x22V AC and 2x30V AC. It is unlikely that you will get the voltage required for the lamps with the same transformer. Therefore, I think a small auxiliary transformer will be needed for this purpose. Or an additional conversion for LED lighting and the associated driver circuit.
Or finding and cannibalizing a same AKAI donor device.
Hi!
Gábor
Bonjour:
SM
https://elektrotanya.com/akai_aa-8080_aa-8030_aa-8080l_aa-8030l_sm_en.pd...
Szia Bálint!
Kicsit nehéz lesz beépíteni a pdf.-et![smiley smiley](//cdn.ckeditor.com/4.14.0/full-all/plugins/smiley/images/regular_smile.png)
Üdv Mali
szia: láthatja, milyent keressen helyette
