AKAI AA-8080 receveur transformateur d alimentation
Bonjour
je recherche un transformateur d alimentation pour ampli tuner AKAI aa8080
Merci
PushyG
PushyG picture
Hi!
You will need a transformer that supplies 2x22V AC and 2x30V AC. It is unlikely that you will get the voltage required for the lamps with the same transformer. Therefore, I think a small auxiliary transformer will be needed for this purpose. Or an additional conversion for LED lighting and the associated driver circuit.
Or finding and cannibalizing a same AKAI donor device.
Gábor
SzBálint
SzBálint picture
Malibu
Malibu picture
Szia Bálint!
Kicsit nehéz lesz beépíteni a pdf.-et
Üdv Mali smiley
SzBálint
SzBálint picture
szia: láthatja, milyent keressen helyette
