Volume control on Yamaha rx-v995 won’t work from remote
I have an older Yamaha RX V995 home theatre receiver. The volume control will not work from the remote. Have two remotes and fresh batteries so problem not in remote. Question: will a reset on the receiver fix this or it it likely some servo motor or part that needs to be replace by a service technician? I can manually turn the knob and control volume just won’t work from remote. Finally what should I expect to pay if this needs servicing ie: parts and labor.
Shizo
Shizo picture
Hi!
Set manually potentiometer for maximum, unplug from wall, and plug in, power on receiver. The motor must rotating knob to zero and back to 30%, if motor not doing this then problem in motor or bad soldering connection or bad motor controller transistor for switching.
