I have an older Yamaha RX V995 home theatre receiver. The volume control will not work from the remote. Have two remotes and fresh batteries so problem not in remote. Question: will a reset on the receiver fix this or it it likely some servo motor or part that needs to be replace by a service technician? I can manually turn the knob and control volume just won’t work from remote. Finally what should I expect to pay if this needs servicing ie: parts and labor.
Hi!
Set manually potentiometer for maximum, unplug from wall, and plug in, power on receiver. The motor must rotating knob to zero and back to 30%, if motor not doing this then problem in motor or bad soldering connection or bad motor controller transistor for switching.
üdv:
https://elektrotanya.com/showresult?what=YAMAHA%20RX-V995&kategoria=&kat...
