1. Close the door or close the door switch
2. Selected the AIRING program
3. Press push button (PB) GENTLE 3 times within 5 seconds afterwards press
Start button.
4. Go to the next step press (PB) START
5. How to leave the test program
- Interrupt of the mains supply for a minimum time of 2 seconds
or
- Open door
or
- Turn rotary selector
or
- Last step of test program is reached and START button is pushed
S:01 Display and button test, Heat Exchanger position test, Drum Light function via corresponding button
Components to be tested:
Buttons, Drum Light, Reed Sensor Heat Exchanger positioning
S:02 Motor is turning clockwise, Heating Element one coil is switched on
Motor, Heating Element
S:03 Motor is turning counter clockwise, The other coil of Heating Element is switched on
Pump is running
Motor, Heating Element, Pump
S:04 Humidity test, Pump and Float Switch Test is running, after water container is drawn out fill water into container housing the pump and floater function is tested
Humidity Sensor, Float Reed Switch
LAST ERROR Last failure which has been detected is displayed
EXIT By pressing the START BUTTON Leave test program
Safety Reset
To carry out the reset procedure the following sequence must be performed within 10 sec.:
a) Turn selector in 6 o’clock position (down)
b) Push “start” button three times
c) Turn selector clockwise one position (airing program)
d) Push “start” button three times
szia: a kezelésiben nincs?
https://www.whirlpool.hu/tamogatas/hasznalati-utmutato-letoltese
Start button.
or
- Open door
or
or
Pump is running
Safety Reset
