strange behaviour of this CD player: when i turn it to standby using the power button, it automatically switches back on immediately
a second thing is that when I eject the CD tray, it immediately closes the tray again, without you getting time to put in the CD
Any clue what might be the cause?
a javításhoz:
https://elektrotanya.com/technics_sl-pg490.pdf/download.html
Hi wim,
please check IC UPDxx power supply, and ceramic capacitors for GND
Hello wim!
Check the power button, it may be conducting with a medium/high resistance value.
Check the limit switches on the CD mechanism, they may be defective in contact.
Regards: Tony
