Hello,
Trying to locate and order a special resistor (Sonic) for a Panasonic SE-2610. This player powerer's on but only works the turntable. No power or sound for AM/FM, cassette player. I located this broken resistor and having a hard time locating one. OR, is there something else in this player I should be checking?
Thank you,
MK
Hello Mark,
schema
Which resistor is broken?
With or without any sound?Does the power amp (STK 435 IC) work?
Thank you for replying. The unit powers up but has no sound, no power to cassette player or AM/FM. Turntable does spin.
I'm told the resistor is a "sonic". None of the resistor businesses can help me determine what type. I would send you a photo of the broken resistor, however i do not see a method to do so on the site. Is there a way?
Much appreciated!
Mark
Hello Mark,
Find the position number of the resistor on the schematics diagram or PCB, for example "R4001" We can't get any further from a photo of a resistor.You can only attach an external picture (cloud) link
Great. I will attempt to locate the schematics and follow your suggestion. Let you know what I find out.
Thank you!
Mark
