Panasonic SE-2610 tuner and cassette player not work
Hello,
Trying to locate and order a special resistor (Sonic) for a Panasonic SE-2610. This player powerer's on but only works the turntable. No power or sound for AM/FM, cassette player. I located this broken resistor and having a hard time locating one. OR, is there something else in this player I should be checking?
Thank you,
MK
torokj
torokj picture
Hello Mark,
schema
Which  resistor is broken?
With or without any sound?Does the power amp (STK 435  IC) work?
Mark A Karns
Mark A Karns picture
Thank you for replying. The unit powers up but has no sound, no power to cassette player or AM/FM. Turntable does spin.
I'm told the resistor is a "sonic". None of the resistor businesses can help me determine what type. I would send you a photo of the broken resistor, however i do not see a method to do so on the site. Is there a way?
Much appreciated!
Mark
torokj
torokj picture
Hello Mark,
Find the position number of the resistor on the schematics diagram or PCB, for example "R4001" We can't get any further from a photo of a resistor.You can only attach an external picture (cloud) link
Mark A Karns
Great. I will attempt to locate the schematics and follow your suggestion. Let you know what I find out.
Thank you!
Mark
