Hello, I have a problem with DCB 115, it does not heat up and the yellow lamp lights up. The elements are in working order,Can you tell me which component will be damaged Add new comment Comments 2024, May 9 - 00:14 #539772 Shizo 15 years 10 months** Hello! Too little informations First: DCB115= Dewalt charger, none of our members know from model number what you want to repair. What is the normal operation without battery ? When you attached to 230V the yellow lamp lights up? Or why say not heat up ? P.S.In 80% of fault is not in charger, fault is in battery pack. If battery pack voltage<13.5V some charger not charge it. 0 2024, May 9 - 15:59 [Shizo: #539772] #539822 nika Visitor Then the charger is charging, if I connect it to this charger, the yellow LED lights up immediately 0
Hello!
