Led tv HK.T.RT 2871 838 board no light problem
My LED TV with HK.T.RT 2871 838 board has some issue with light LEDs probably, i can switch on and off TV with Remote as the red/green lights to on off through remote but no light on display, can any tell me how many volts should be there in the supply red/white pair that supplies voltage to led strip necessary for lighting up the screen
manyizoli
manyizoli picture
Hi,
Can it be turned on and off with a remote control?
If you light up the display the image is dimly visible?
ityvity
ityvity picture
HI.The background lighting is dead. The led driver is disabled , and there is no voltage on the led. LED background replacement..
zsugori
zsugori picture
