Hi,
Despite the fact that it’s difficult to read screen information, it appears that the screen works properly. Of course I need to point a light on it to be able to read the track number, the resting time and so on …
Does it mean that the screen is dead or do you think it’s only a lamp which has to be changed ?
Thank you in advance for your advice.
Regards,
Armel
hello: a szervizkönyv szerin ellenőrizni kell a kijelző és a táp feszültségeit
https://elektrotanya.com/nad_c-521_sch.pdf/download.html
Hi!
The problem is probably with the backlight of the display, but it is not solved with a lamp, but with a special film.
If it is working properly, it will glow blue.
The display is LCD, but without the backlight, the described error occurs.
Its repair requires a trained specialist.
Hifista.
Bad news but thanks a lot.
