Helo
Try removing the jack plug and touching the inner contact of the jack socket with a thin metal rod at maximum volume. If you hear any sound or a crackling sound, the amplifier is working and the problem is likely in the cable or the pickup.
Thank you for your response. The fact is that the amplifier lights comes on (green light...always has), especially now with a new battery. The problem is that is does not amplify any sound coming from my mandolin, it is totally mute.
Hello,
I'd check the battery and battery connections.
Helo
Then you have to take the amplifier out of its box and check its operation. So I can't give any other advice from a distance.
