BOSE solo sound system II series smps problem.
8 posts / 0 new
gianluu12
gianluu12 picture
Hello, I need the schematic to repair this smps, I have only 2v out. First section till big size cap after bridge is ok.
in pdf area there is only the list of components without the circuit diagram.
thanks
File attachment:
ponsi
ponsi picture
Hola revisa o reemplaza el transistor mos.fet de la fuente.
zsugori
zsugori picture
SzBálint
SzBálint picture
hello:
pontos típusszám kell az azonosításhoz
Shizo
Shizo picture
Hello
If nobody find schematic, then add pwm ic name and we can help to you!
gianluu12
gianluu12 picture
excuse me, is this component  a zener or what?  thanks
https://postimg.cc/V0CfMWsB
zsugori
zsugori picture
capacitor , resistor.....? fel kell szedni megmérni hot air
gianluu12
gianluu12 picture
Thanks! I uploaded more photos, the ic pwm controller  is 28610
this image is more than 3mb ,I uploaded on ebb : https://ibb.co/R43yCYH8
File csatolás:
