Hello, I need the schematic to repair this smps, I have only 2v out. First section till big size cap after bridge is ok.
in pdf area there is only the list of components without the circuit diagram.
thanks
2025, January 28 - 11:46
#1
Hola revisa o reemplaza el transistor mos.fet de la fuente.
touch20 32.old
hello:
pontos típusszám kell az azonosításhoz
Hello
If nobody find schematic, then add pwm ic name and we can help to you!
excuse me, is this component a zener or what? thanks
https://postimg.cc/V0CfMWsB
capacitor , resistor.....? fel kell szedni megmérni hot air
Thanks! I uploaded more photos, the ic pwm controller is 28610
this image is more than 3mb ,I uploaded on ebb : https://ibb.co/R43yCYH8
