I replaced a broken jack for the input on a washburn bad dog amp and I get a hum but no sound from the jack. No components seem burnt not sure what to check the jack measures the same as the other 2 on the posts so I don't think it's soldering
You maybe replaced with wrong jack input switch, 2types have a combined switch with socket. Normally open (NO) or Normally Closed (NC), when you plug in then your switch now connect input to the ground (NO type)
Mér ki ohmikusan,szerintem rövid zárat csináltál.
Csak egy forrasztás
