Lenne ez ketyere .
Nincs életjel, a stby led nem ég.
Az V+5,6VSt eljut az előlapra, ill. a ebből a feszből levő V+5VH megvan a procin.
Nem ülteti meg a proci ezt a feszt.
A gombok jónak tűnnek. A procit átforrasztottam, de semmi..:(
A 49. oldaltól taglalja az előlapot:
https://elektrotanya.com/pioneer_vsx-1015-k,s_sm.pdf/download.html
Halott lenne chip......?
Kösz
Hi!
Kösz mindenkinek IC501 62 pin nem ért oda a delej, egy furatgalván ko...
Nem lehet a main panelhez direktben hozzáférni, csak hidegen méricskéltem ohmikusan...
A super kapac kell bele, vagy hagyjam a fenébe????
Ha nincs, vagy drága, hülye alakú, mehet oda 2 alkáli jó fajta elem egy diódával. A következő 20 évre le van tudva. Ezek a kondik nem túl tartósak.
Kell bele, mert azzal tartja meg a beállításokat áramszünet esetén.
Nélküle mindig alaphelyzetből indul.
szia: a procik általában több lábon kapnak tápfeszültségeket, van amelyik négyet is, külön stab. kockákról
![](data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4RDaRXhpZgAATU0AKgAAAAgABAE7AAIAAAAFAAAISodpAAQAAAABAAAIUJydAAEAAAAKAAAQyOocAAcAAAgMAAAAPgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAERlbGwAAAAFkAMAAgAAABQAABCekAQAAgAAABQAABCykpEAAgAAAAM4NQAAkpIAAgAAAAM4NQAA6hwABwAACAwAAAiSAAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMjAyMjoxMToyMiAxNDo1Nzo1MQAyMDIyOjExOjIyIDE0OjU3OjUxAAAARABlAGwAbAAAAP/hCxdodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBiZWdpbj0n77u/JyBpZD0nVzVNME1wQ2VoaUh6cmVTek5UY3prYzlkJz8+DQo8eDp4bXBtZXRhIHhtbG5zOng9ImFkb2JlOm5zOm1ldGEvIj48cmRmOlJERiB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMiPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6ZGM9Imh0dHA6Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvIi8+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczp4bXA9Imh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC8iPjx4bXA6Q3JlYXRlRGF0ZT4yMDIyLTExLTIyVDE0OjU3OjUxLjg1MTwveG1wOkNyZWF0ZURhdGU+PC9yZGY6RGVzY3JpcHRpb24+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczpkYz0iaHR0cDovL3B1cmwub3JnL2RjL2VsZW1lbnRzLzEuMS8iPjxkYzpjcmVhdG9yPjxyZGY6U2VxIHhtbG5zOnJkZj0iaHR0cDovL3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+PHJkZjpsaT5EZWxsPC9yZGY6bGk+PC9yZGY6U2VxPg0KCQkJPC9kYzpjcmVhdG9yPjwvcmRmOkRlc2NyaXB0aW9uPjwvcmRmOlJERj48L3g6eG1wbWV0YT4NCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgPD94cGFja2V0IGVuZD0ndyc/Pv/bAEMABwUFBgUEBwYFBggHBwgKEQsKCQkKFQ8QDBEYFRoZGBUYFxseJyEbHSUdFxgiLiIlKCkrLCsaIC8zLyoyJyorKv/bAEMBBwgICgkKFAsLFCocGBwqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKv/AABEIAVADNQMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/APpGiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK56bwL4fn1BruS1m+dy72y3cy27sTks0AbyySeTleTXQ0UeYdLBXJfDWUQ/B/wzKwJCaPbsQBknEQre1zWbTw7oN7rGpMy2llC00pRdzbVGeB3Nea/Cv4qeCz8MdEtL3X7LTrmwtI7SaC+nSJ96IASATyp7H+uRSd7aAi3LrVlcaHZxXmgWemLdXlrqGnrayRSpPvuIwzZMeFlG8FgATzw2ckenVw3/CY/C0W6wDXPC/krP9pWPz4Nqy7t3mAdmzznrmr/APwtDwJ/0OGif+B8f+NVdWt/XQCb4j/8ks8V/wDYFvP/AEQ9Hw4/5JZ4U/7Atn/6ISuV+IvxN8FS/DPxHBa+J9Mu7i502e3hhtrpJHd5EKKAqnPVhn0GT2pPhz8TvBUfwy8OQXfiXTbO4ttNgt5YLq6SORHjQI2VJzjKkj1GD3pAdX8R/wDklniv/sC3n/oh68w1O80231q6tLXVL11eefTJI18KXMzRRys0kimTgM+fusAeCDtbrXVePfiN4Mvvhx4ltLPxVo89xPpN1FFFHexs0jtCwCgA8kk4xTr54tS8Or4vmvLOHVdNnkuI1AKjCb1FtIA2WbkjJ5DHIHahaSTY7XWm/wDX6nV+KUWPwLqSJu2rZsBu642963KxPFLNN4H1J/LZWazdimMkfLnFO/4S/wAPf9Bmz/7/AApvclbaDvFX/Is3f/AP/Q1rXrlPEHiXRb7Q57az1O2nnlZFSOOQFmO9eAK6ukMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKw7rxlodlfvaXF1KGifZLMlpK8ELf3ZJlUxoeRwzDrR1sBuUViXni/RbDUzY3NxMJVZUkkS0meGFmxtEkqqUQnI4Zh1HqKSTxlocWqGwe6k8xZRC0wtZTAkhOAjThfLVskDaWzkgUbgbleJfA3/AJKn8Wf+w0P/AEfdV6vH4o0eU2qxXe97ueS3hRYnLO8bFX+XGQFKkFj8vvyK8o+Bv/JU/iz/ANhof+j7qgD22iiigAooooAKKKKACiiigArG8If8ibpP/Xqn8q2axvCH/Im6T/16p/KgDZrm/hx/ySzwp/2BbP8A9EJXSVzfw4/5JZ4U/wCwLZ/+iEoA2NX/AOQJff8AXvJ/6CaNI/5Alj/17x/+gijV/wDkCX3/AF7yf+gmjSP+QJY/9e8f/oIoAr+Jv+RS1f8A68Zv/RZq/af8ecP/AFzX+VUPE3/Ipav/ANeM3/os1ftP+POH/rmv8qAMvxf/AMibq3/Xq/8AKtmsbxf/AMibq3/Xq/8AKtmgDI8Vf8izd/8AAP8A0Na16yPFX/Is3f8AwD/0Na16ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAIrm2gvbWW2vIY7i3mQpLFKgZHUjBUg8EEdjXJ/CSxtLH4SeG1sreKATafDNII0C75GQFmPqSe9aGveOtC8NXqWusSX0UkhVUMWmXMyMzfdUPHGylj/dzmue8I/Ejw0mjaTpUlxfR3e+PTysmlXSKtzwPKLmPaG9iaAPQqKKKAK2o6bZavp01hqlrDeWk67ZYJ0Do468g+/NJpmmWOjabDp+k2kNnZwLtiggQKiDOeAPck+5OatUUAFZcnhjQZtZXV5tF099SX7t41qhmH/A8Z/WtSigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKzr3X9L0+8Npd3iJcCNZTEAWYIxIViADgEqwB77T6Vo1zdj/yVPXf+wLpv/o++oAu/8JVo3/P5/wCQn/wrgDqzaf4e1bwxb2L3q38t2YtSyogVZ3ZsyqxEmV3kYVGzgcjPHq1FG+jGm1sePXtw1neXEOjx6il3IIlj1G2uF+xzBUVQ1zBI2d3y4YohJAGDnppaVr8ujac3h6LT1uQbySVdSmVTamN5jISybhKXAYjG3BYD5sV6fRTu+pNkeW+CtKuNP1ltW0xzfzT3tzDqNpJMu63t5LiSSGWMEjaOclf4tx6lcVifA3/kqfxZ/wCw0P8A0fdV6xrGjveSRX2nSra6pbAiGcjKuvUxyD+JD6dQeRyK8i+AbzSfEj4pvcxCCZtWQyRB9wRvOucrnvg8ZovpYfVs9yooopAFFFFABRRRQAUUUUAFY3hD/kTdJ/69U/lWzWN4Q/5E3Sf+vVP5UAbNc38OP+SWeFP+wLZ/+iErpK5v4cf8ks8Kf9gWz/8ARCUAbGr/APIEvv8Ar3k/9BNGkf8AIEsf+veP/wBBFGr/APIEvv8Ar3k/9BNGkf8AIEsf+veP/wBBFAFfxN/yKWr/APXjN/6LNX7T/jzh/wCua/yqh4m/5FLV/wDrxm/9Fmr9p/x5w/8AXNf5UAZfi/8A5E3Vv+vV/wCVbNY3i/8A5E3Vv+vV/wCVbNAGR4q/5Fm7/wCAf+hrWvWR4q/5Fm7/AOAf+hrWvQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABWVq3iXTNFuEgvZLhpnXf5VraS3LKucbmWJWKrn+I4HvWrXH6xZ6xZa/qV1ptnf3CapbwRLc6dJbCa0aMtnIuDtKkN2DHluOhpAZWtTvr/jBV0zV9Ne+h00XWgW7lmQeYdkl4x27WZVJCKM/wAWcbuMzQ7jw5pGv2cst5dXWn6ZYpLpggsLqfHn5Mt5cusW1JHYOAWPChzxuOLeneEPEUrR32oRRQ6tZ6bEttcAxBftCTTHYRGAArI4BIUAhjwCOGeGNO8S+G40WfwvdXclxolpasYbm28uGZDNuVy0oOB5i8qrcZx6VXR/13/r/hx6fl+l/wA/6sd9/wAJDpX2bULgXatDpqb7p1ViEXyxJkYHzfIQflzWhFIs0KSxnKOoZTjqDXmlv4X1zQfDuqeHrbTZdSGqWEVsl9FNEsUDrbLA3mB3D4yu4bVbg9K9ItYfs9nDCTuMcapn1wMU2ld2FpZf12/4JLRRRUgFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRVHWtTTRdDvNSkjaVbWFpSinBbA6ZPT60AXq5ux/5Knrv/AGBdN/8AR99UFr4yuBqVlpeq6dFa6lcXKxNHFdebGY2ikdZUfapcZjKkYGD+Gc+z8S2K/F7Wbcwapvk0+wtQRpN0UDrPeAkv5e0J8wxITsPJDHacOwHd0VyWveJdQ0XxJFbWEK6556qW0q1ULdQDn95uJ2bDj+Mp3wxPy10Wl3k9/p8dxdadcabK+c21y0ZdMHHJjZl568E9aW6uGzLdFFFABXiXwN/5Kn8Wf+w0P/R91XtteJfA3/kqfxZ/7DQ/9H3VAHttFFFABRRRQAUUUUAFFFFABWN4Q/5E3Sf+vVP5Vs1jeEP+RN0n/r1T+VAGzXN/Dj/klnhT/sC2f/ohK6Sub+HH/JLPCn/YFs//AEQlAGxq/wDyBL7/AK95P/QTRpH/ACBLH/r3j/8AQRRq/wDyBL7/AK95P/QTRpH/ACBLH/r3j/8AQRQBX8Tf8ilq/wD14zf+izV+0/484f8Armv8qoeJv+RS1f8A68Zv/RZq/af8ecP/AFzX+VAGX4v/AORN1b/r1f8AlWzWN4v/AORN1b/r1f8AlWzQBkeKv+RZu/8AgH/oa1r1keKv+RZu/wDgH/oa1r0AFFFFABRRRQAUUUUAFFFUNZ1eDQ9PF7dpK0PmxxOY1B2b3CBjkj5QWBJ7CgC/RWfBrVtcaxf6eiyBtPSN55mwIwXBIXOc5AAJ46MKrXviFrbXo9KtdIvtQlMaSyy2zQBLdGYqGbzJFJ+6x+UMeKANmioL69t9N0+4vb2QRW9vG0srn+FVGSfyrEtPGUFxfWdndaXqVhc3k/kxR3UcY/5ZPIHJV2GCsbcZ3A4BAoWobHRUVR07V4NSutRt4EkV9Pufs0pcABm8tHyuD0w4645zV6gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAorj/AIreKZ/Bvwy1jWbFwl5FEI7ZiAcSOwUHB4OM5x7V0ejanFrOhWOqW/8Aqr23juEHoHUMP50AXaKwYfF+nz2djPHFcbr6+awjgKr5iyoXD7hnAC+WxJBPA71e1jWIdH0qa+eKW68p0jENuV3u7MFVRuYLklh1I60B1saFFY9l4iFzqVpp93pl7p15dW8twsNyYmKLG6Kdxjdhk+YpGCeM5x0rP/4Tq2mEa6ZpOpajO7T7oLcQh0SGUxO53yKMbhwASx9KdgOooqG0uo72yhuoQ4jmjWRQ6lWAIzyDyD7GpqWwBRRRQAUUUUAFFFFABRRRQAUUUUAFZ+vyXUXh6/fToVnulgfyonAIc46YPB+netCs3xHJp8fhu+Os232uxMJWa32BvNU8bcHrnOPxpS2GtzxvU7m7svDurNpV1eXMNlpt3Lp/2zS4rObTlFrLuli2RRtFh9qqf4stjoWrotW1y48A2/iG60ojxRqC2ss09yxLTW3lIzxrcYIj8tSzHapjOCdqMSTWHoq+FvBuo61rFl4YnjvNG0+V4bSXRfLe2eOJ5WV7yMPFkoQu7OcEZ3E10DXtlZaNqV74Ws8+ErGO4k1W1ukV4Jo0VjNHDA2GDnBGGKR89DVvZE9SPxlfLD4yvEd/ESMXtY2/si3umQ27f63JhUjfjv8AfAHykV2Xga4nufC6Pcfbdq3E6QG/jkScwiVhGXEgD52BeW5PU1z+uxi18Va1eTeL9Q0SIQW8jQ2EMMpYfcBIeFzuLHCqOW7A11nhieO48PW8sOq3OrK27/SruJY5SdxBV0VEClT8uNoIxzzUx+F/1/X/AA43v/X9f8MjWooooAK8S+Bv/JU/iz/2Gh/6Puq9trxL4G/8lT+LP/YaH/o+6oA9tooooAKKKKACiiigAooooAKxvCH/ACJuk/8AXqn8q2axvCH/ACJuk/8AXqn8qANmub+HH/JLPCn/AGBbP/0QldJXN/Dj/klnhT/sC2f/AKISgDY1f/kCX3/XvJ/6CaNI/wCQJY/9e8f/AKCKNX/5Al9/17yf+gmjSP8AkCWP/XvH/wCgigCv4m/5FLV/+vGb/wBFmr9p/wAecP8A1zX+VUPE3/Ipav8A9eM3/os1ftP+POH/AK5r/KgDL8X/APIm6t/16v8AyrZrG8X/APIm6t/16v8AyrZoAyPFX/Is3f8AwD/0Na16yPFX/Is3f/AP/Q1rXoAKKKKACiiigAooooAKp6tpsOsaNeadc/6q7heF/YMMZq5RSeqsNOzucE/gbW7r4e3+mXOt/Z9b1HzZLu4tFTyp3ZNioxkjYhNoQEqA3HBo1XwPqV1eQsjWV/P5UcY1u9by760KOzZQRxiNuGIGPL77i2a3fHmvHwv4A1vWUcJLaWcjwk9PMxhP/HitRfDrxAfFPw40PWHl86W4tE858Y3Sr8kn0+ZWqrsm2liXxBHb+JvD2o6EjXkD31u8CzNZzKqEgjO4qBj8a5y18E61Z3cOqWdtpVlPaXKTwaVDdSfZXIiljdzJ5QKu4lBOEPKDOck10tx4v0+2s9SmkiuN2nXiWckIVd7yPs2BRnBDeYuMkde1aOq6rBpOk3l/OGkSzhaaSOLBcgAnABIGTjjJFCbSuv66j30/rsUvDek3enLqN1qfkLealdm6lit3LxxHy0QKrFVLcIOSo5PQVtVS0q/uNRtDNd6VeaW+7aIbxoWcj+9+6kdcfjnjpVG78UwWut/2cljfXIR40uLmCNWitmkPyB8sG5yD8qtgEFsCjqkLzNuiubt/GS3czC00PVZoGaRLa5RYfLunj3ZRcyZU5VgDIEU468ipfDviiXxDPcp/YGqadHbSPE8149sV8xTgoBHM5z74xx1pbjN+iiigAooooAKKKKACiiigDKn8Q2Vrqd9ZXIkhaysxevI4ARoiWBKnPJG3nOOo9atadqMeo6baXaxyW/2qBZ1hnwJFUgHBAJ5GRnBNYHjLwpc+IprB7GeGAAtbX3m5/e2jlTIi4/iJRcZ45NZ2uadJF8TtEd/FN5am+t7qG1sBHblW2iJ2Rcw7thVCWy+7ptI5oW39ef56fiPr/X9d/wADVtvG0c2jNq0+i6naWLPCsE0xgIuBLIEVlCSsQMsCdwU4PTPFWtW8W2Oj3txaXEVxJNDDDKFiVT5pllMUaLlh8xYY5wBkc9a5W1+H2oLY3UCW+k6OPJhSKHTpJHiuZYpVkWWQMgKn5AuMuQGPzHAq/eeGtd1htQv9TtdGFzdW8Fr/AGa0rXNtNFHI7sryNEpG7fjIQ7cA809P67f1/wAN0DTX+u3/AAf8zptH1c6tDMZdOvNNngfZJb3ipuU4BBBRmRgQeqsfQ8jFaNc54P0O90SC8F4kNrHPKGhsLa7kuYrYBcHa8iqeTzgKAO3c10dDJQUUUUhhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUVU1XUU0jR7vUZoZpo7WFpnjgUM7BRk7QSMnA9arxa9aT6xBp1uJJXms/tolUDYkeQFyc5y2Tjj+E0B/X9feadFY2r+Iv7MuLO3s9LvNXuLxXkjisXhBCJtyxMsiDHzr0JPNEviezht9bmkhuANETdcrtXLfuhLhfmwflOOcc/nR0uNJt2Rs0VykfxF0WTTvEN4UukTw/8A8fSNGu58oHGwBuc5wM45BFdDpmoRatpNpqNurrDdwJOiyABgrKCAcE8807fp+OxN1/XkWqKKKQwooooA+f8A9q/XPI8M6JoaHm7unuZMNjAjXaMjvkyH2+X6V2P7POu/218HNOjdi0unSSWbk+incv4bWUfhUvxi+H3hzxF4V1nxFq9nJPqWmaPcG0kFxIqxlEd1OwMFPzHPI54BrqPB/gTw/wCBLO4tfDFo9pBcyCSRGneQFgMZ+YnHHpQBUt/CN3F45vNUN4iaa6PLaxJzJDcyKqSPggrjamR15d8j1op4G1WHTtXiutUGvC7vFuI7PVViWGQKUOXaGFWVzsx/Eo4O0813dFC0/L9Qev5nBaf4T13RLm01PTYdMe4iW4iGltdyR21vFK0bBI5REThTFnGwA7jjbgVFceBdQWwtImsdI1hkM8ri6nktWtppZWkZ4Zkjd8fPtx8udoORXoVFN6qwFHRbO50/Q7Kzvrpry5ggSOW4brIwGC1XqKKG7u4BRRRSAKKKKACiiigAooooAKKKKACqOt6Umt6Lc6dJPLbrOuPOh270IIII3AjOR3BFXqKAOJHgKW1tdU+2+INc1y1v45TeaY4tUF7ui8spuWOMqSoABDoMgZI5NYGr6befELxTrOiT6bqHhZRoil7orbmWYzmeILKYpm3x4UlU9VfJX5d3qtc3Y/8AJU9d/wCwLpv/AKPvqdwGan4SnvvEAvY9RSOzeaK6mtXt9xeaIYjIfcMKCASuDkqMEc1q6DpT6PpfkXFz9quJJZJ55hHsDyOxZiFydoycAZPHc9a0qKS0VgeoUUUUAFeJfA3/AJKn8Wf+w0P/AEfdV7bXiXwN/wCSp/Fn/sND/wBH3VAHttFFFABRRRQAUUUUAFFFFABWN4Q/5E3Sf+vVP5Vs1jeEP+RN0n/r1T+VAGzXN/Dj/klnhT/sC2f/AKISukrm/hx/ySzwp/2BbP8A9EJQBsav/wAgS+/695P/AEE0aR/yBLH/AK94/wD0EUav/wAgS+/695P/AEE0aR/yBLH/AK94/wD0EUAV/E3/ACKWr/8AXjN/6LNX7T/jzh/65r/KqHib/kUtX/68Zv8A0Wav2n/HnD/1zX+VAGX4v/5E3Vv+vV/5Vs1jeL/+RN1b/r1f+VbNAGR4q/5Fm7/4B/6Gta9ZHir/AJFm7/4B/wChrWvQAUUUUAFFFFABRRRQAUUUUAeLftRa7/Z3wyt9KjYCTVL1FZfWOP5yf++hH+dQ/sta/wD2h8Pb7SJJd8umXmVU/wAMUgyv/jyyV6V4u+Hnhfx21o3irTPt5sw4g/0iWLZuxu+4wznaOvpWH8HfBegeHPAukaro1iba91bS7Sa9k8+RxK5iDE7WYheWPQDrQBa8U6T/AGb4gbxZd3SR6HYW323UbcAmSSS3VzGVHQ8OSckHKJUSeENQ1CTVdSTxDLqtlq1pF5NrfJD5My4YgSeVEjhQGGCrZ5+bd0rH/aM13+x/g9ewIzLLqc0dopXrgne34bUI/GtT4Ha7/b3wc0OVmUy2sRs5Av8AD5R2qP8AvgKfxo6WB6u5reG7GXwzb3f9oWsVmt5P5kWn6Uk1zBagKqkKwjXG4jcflUZPfknKu/Btzf8AiifV9NjtkS9u4Lo39w0sV1aeUEVkjjKcq6pg5ZfvHIYYrv6Kd9bh0scNpXhDVbTxPBfPb6ZZCOd5bm9sLiRX1EMrDEtuI1jU5KktuY5XjGa6PQNLn0qPUFuGjY3N/NcpsJOFdsgHIHNa1FLb+v67A9f69f8AMKKwtT8ZaNpGqPp97JefaI4lml8jT7idIkYkBneNGVB8rfeI6Grt1rumWU2nxXF5GsmpP5dmoy3nnaX+XGeNoJz0/OgDQormh8QNAE0sUz6jbSRRGVlutIu4dy7gvy74huJZgAFySTgA1s6Vq1nrNiLvT5HeLcUIkieJ0YHBVkcBlI9CAaA2LlFFFABRRRQAV83/ABi8ef2P+0R4VC3Pl22ieUbn0Xzm/eZ5/wCee2vpCvkH4m/C/wCIeufE++1NtELLq+pSQ6e32yAeYER2Qffyv7qEnnHTHUgUAfX1FZfhgaivhPSl12LydSWziW7TcrYlCgNypI656E1qUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAI6q6MjgMrDBB7iuL8P+CdR0vS9Rt59Ye2uJSlvaXVkqM8VpFnyoz5qMufmbPynrwe9drXMfEnXh4a+GmvaqJPKkhs3WJ/SR/kT/wAeZaVt/MDjfD/huXxB8PtAubCTTvE0a2TQRz6o/lG0PyqTA0UXIVozgMofIB3jFb914T1+K11XT7GayvLfWrZIbq8vJ3SaFxAIWcIqMJMhQ2Cyc55rj/2XtfOpfDe60uWXfLpd4wAPVY5BuX/x7fXtVU3e9+o02ndHnMvw51A6lI0V1aizubmR7qNi26WNQrQduqyKcjphjXa+H9Pl0nw1pmnXDI01paRQO0ZJUsqAEjIHHFaNFCbS5fT8COVXv6/iFFFFIoKKo65q0Og+HtR1e6R5INPtZbqRIwNzLGhYgZwM4FYf/CVa/wD9E/1v/wADLD/5IoAX4nMV+E/ioqcH+ybkfnE1dTXmPxE8Sa3cfDPxHDP4I1e0ik0ydXnlurJliBjOWIWcsQOvAJ9q6T/hKtf/AOif63/4GWH/AMkUAdVRXK/8JVr/AP0T/W//AAMsP/kij/hKtf8A+if63/4GWH/yRQB1VFcr/wAJVr//AET/AFv/AMDLD/5Io/4SrX/+if63/wCBlh/8kUAdVRXK/wDCVa//ANE/1v8A8DLD/wCSKP8AhKtf/wCif63/AOBlh/8AJFAHVUVyv/CVa/8A9E/1v/wMsP8A5Io/4SrX/wDon+t/+Blh/wDJFAHVUVyv/CVa/wD9E/1v/wADLD/5IrjvF3xZ8W6B4q0DTLXwBfLFqU3luLmWJ5Jjn7sbRSMisBk/OenYAZoA9borm/8AhKNX/wChE8Qf9/8AT/8A5Kqsnj9YvFmj+HtV8OaxpV3rPn/ZHuTavG3kpvfJimcjjHbkn64AOtooooAKx9Y1+TS723tLTRr/AFa4mjeXy7JoF2IpUEkyyIOrDoSa2Kxpv+R6tP8AsGz/APo2KgCp/wAJRq//AEIniD/v/p//AMlUf8JRq/8A0IniD/v/AKf/APJVdJRQBzf/AAlGr/8AQieIP+/+n/8AyVXP2fiPVB8SdZlHgvXGdtJsFMImsd6ATXhDH/SduDuIGCT8pyBxn0Subsf+Sp67/wBgXTf/AEffUAH/AAlGr/8AQieIP+/+n/8AyVR/wlGr/wDQieIP+/8Ap/8A8lV0lFAHk/hv4u+Ida+IWu+H5vAWpCLTQSohkhEyYYKPMMkixncDkbXPtuGWHaf8JRq//QieIP8Av/p//wAlVd07/kZtZ/7Yf+gGtegDH0vxEt/eGxvdOvNIvihlS1vjEWlQHBZWjd1bBxkBsjIyBkZ8a+FOsQaD47+MGoXKPIsWtIqxx43SO1xcqqDPcsQPxr27V9It9ZsxDOzxSxuJLe4iOJIJB0dD2PJGOhBIIIJFeGfB/Rf7a8X/ABa0zVZ90r6tHvuIF2YlWe5YSKDnGGAYA5/Gga3PVbzxlf6EGPifRY7bzIJprX7Bdm580xoXMZzGm1yoJAG4cHmoLbx9J/Y8+o3tjZSwbY/ssmk6kLyOd5HCJGWKJtcsw7EYOc8VZm8KarqkyT67r6ST2sci2Mmn2ZtvId12+a26R9zgZHG0cnjmqbfDyTUJ7m61q/szeSRLHHNpmn/ZcMsiyJI4Mj+YyugI5AALDHNNWvqLoaiat4pKywyeHbBLsIJIT/ajm3dc4KtJ5G5XHXGwg/3qk8H65qniLRIdU1PTLPT4bmNZLdbe+a4Yg9d2Yk2np03VNpelavFfPea7rEd7L5XkxxWlu1tAoJyWKGR9z8Abs8DoBk5n8O6R/YPhyx0rz/tH2SFYvN2bd+O+MnH50AaVFFFIAooooAKxvCH/ACJuk/8AXqn8q2axvCH/ACJuk/8AXqn8qANmub+HH/JLPCn/AGBbP/0QldJXN/Dj/klnhT/sC2f/AKISgDY1f/kCX3/XvJ/6CaNI/wCQJY/9e8f/AKCKNX/5Al9/17yf+gmjSP8AkCWP/XvH/wCgigCv4m/5FLV/+vGb/wBFmr9p/wAecP8A1zX+VUPE3/Ipav8A9eM3/os1ftP+POH/AK5r/KgDL8X/APIm6t/16v8AyrZrG8X/APIm6t/16v8AyrZoAyPFX/Is3f8AwD/0Na16yPFX/Is3f/AP/Q1rXoAKKKKACiiigAooooAKKKKAKupu0ekXjxsVdYHKsDgghTzVfw5aQWHhbSrO0Ty4LeyhiiTJO1VQADJ5PA71Nq//ACBL7/r3k/8AQTRpH/IEsf8Ar3j/APQRQB41+0n4S8R+J9GsrnSIY20vRre4vbxmmVTwoPCnkkKrdPWtj4B+CvFHgPQdV0rxRbQQwy3KXFsYZlk3MV2vnHT7if5Fdz4/gkuvhr4mt4F3yzaRdIi5AyxhYAc+9b0biSJHHAZQRn3oAdRRRQAUUUUAcbqC6zp/jbVbuy8PXWp2+oafbwRTRT26Ro6NNkSB5FYD94vKq3f6Vhp4A8SafqHhiW31Oxu4dNe2idZLJi9vHHAyuVfzgCGYngJnlc5C4rbn1vxALjxZChtEns44f7OjDjblw2Ms4UbiccHjOBnqayk13XF029srbUNVm1FXgIt9QtbWG/jRi2/ysKsEh2qdvXlWyTwKaev3f1+OoXun81+huNpuoKNZ1S50lb+8mvE+z2zvFuFvERsKFsqGzvkUMR8zDJHax4H07UNO0i6GqpcLJcXkk6m8aI3DBgOZTF+73Zz9zjaFrnzq+rzaDcNDr2pKNPlk+0MNLVtSzsQxxmEQsjAliSyqBt24PVqbY+JNWmvtP1LWLvU7bTZYbRQ1lDbNZSzSKMhmZTKQXcKChwMckULT8F/Xrb+tAev4v+vvPRqK43wPqepTSm38R3Wrrqc9stz9k1GG2REXOGMXkqGwCwUiQ7hxxzk9lQ1YOtgooopAFc54jjln8T+EVhjLCHUpriVsgBEFncR55PPzSoOPWujrI1H/AJGbRv8Atv8A+gCgDXooooAKKKKACiiigDnfG9u58Pf2jbIzXOkTJfxBRlm8s5dR/vRl1/GuZi16/wBK8K3PibTtHvNQm12+FyHiaECKAukcQYSSIfmjAIwDgsc4r0iihaf1/XZB2/r+t2eXa5c2Q8e2+q6hZaRJqjJaR22kanbK9+nztloJAxUFd+4lN4+Xkr1rrPiC94nge+Nhw5MSyEkgLEZFEhJHIATdkjtmukI3KQc4IxwcVUt9MgtZhLHJdMwGMS3csi/kzEUdLDWjuePM2hPZpA8/huHSIL2VoZLmAHRL3McWdgL7YnBJxgsNwkPXONSXQNA1u28D3eoeG9PaSfUHt3+0QrceZEsFxtUO65eLKhlz22nFehaf4lsNS8T6voVszG80hYGucjj96pZQPwHP1HrWvVJi/wAn+I2KKOGFIoUWONFCoiDAUDoAOwp1FFSAUUUUAFFFFABRRRQAV5z8b/C/iPxl4CTRfCsUcks12j3IklEYMSgnGT/tbfyr0aigD5+/Zw8D+KvC91Nq2pQQromt6dFPCyTqzFjhoyV6j5XavoGuW+GE4uPhP4WdQQBpNsnPqsar/SupoAKKKKACiiigDm/iP/ySzxX/ANgW8/8ARD10lc38R/8Aklniv/sC3n/oh66SgDlfih/ySfxT/wBgm5/9FtXVV538ddS1XTPhFqx0XTvtxuIzb3RwT9nt3Vg8uByccewzk8A1Po3jXxnd6HZXGofDfUlupYEaUR3trGu4jnCSSh1/3WGR0PSgDvaK4/8A4S3xT/0TnVv/AAY2P/x6j/hLfFP/AETnVv8AwY2P/wAeoA7CivJPiF8TfHvhvQoLvR/h9cQu9ykLyXskd0g3fKqhLeUtlmKgE4GSByWFdNbeL/FslpC8/wAONUWVkUuq6jZYDY5AzKD+YBoA7WiuP/4S3xT/ANE51b/wY2P/AMeo/wCEt8U/9E51b/wY2P8A8eoA7CiuP/4S3xT/ANE51b/wY2P/AMep1n4z1Vtc03T9Y8IahpKajO1vFczXdtKokWKSXBEcjN92Ju2KAOurm/FH/IxeDP8AsNSf+m+8rpCcda5rxQc+IvBuP+g1J/6b7ugDpa828bf8l2+GH/cW/wDSZa9Jrzbxt/yXb4Yf9xb/ANJloA9JooooAKxpv+R6tP8AsGz/APo2KtkkKMscAdzWNL/yPNp/2DZ//RsVAGzWVqGszWmppY2mmXF9K0JmbynjUKucfxsO/pWrWR/zO3/cP/8AalADf7Y1X/oWrz/wIt//AI5XPWWq6kPiZrTjw/dl20jTwY/PgyoE15g5345yfyPtXdVzdj/yVPXf+wLpv/o++oAt/wBsar/0LV5/4EW//wAco/tjVf8AoWrz/wACLf8A+OVs0UAcjp+ramPEWrkeHbwk+TlftEHy/If9utX+2NV/6Fq8/wDAi3/+OU7Tv+Rm1n/th/6Aa16AMb+2NV/6Fq8/8CLf/wCOV438F7+9g+JnxSeDSLi5eTVwZI0liUwnzrnglmAPU9M9K99rxL4G/wDJU/iz/wBhof8Ao+6oA9U/tjVf+havP/Ai3/8AjlH9sar/ANC1ef8AgRb/APxytmigDG/tjVf+havP/Ai3/wDjlWtH1T+1rFrg20tq6TSQvFKVJVkcqeVJHb1q/WN4Z/48b3/sJXf/AKOagDZooooAKKKKACsbwh/yJuk/9eqfyrZrmtGOt6TotpYPoyytbRLGXW7UBscZ5FAHS1zfw4/5JZ4U/wCwLZ/+iEq7/aOs/wDQB/8AJxP8K534fX+rJ8M/DCxaL5ka6RaBX+1INw8lcHHagDrdX/5Al9/17yf+gmjSP+QJY/8AXvH/AOgisnVdR1g6NehtDwPs75P2tOPlPtRpWo6wNGsguh5H2dMH7WnPyj2oAveJv+RS1f8A68Zv/RZq/af8ecP/AFzX+Vc34j1DV28K6qH0PapspgW+1ocDYeelXbXUdZ+xw40LI8tf+XxPT6UAP8X/APIm6t/16v8AyrZrkfFeoau3hHVA+ibFNs+W+1occemK1/7R1n/oA/8Ak4n+FAB4q/5Fm7/4B/6Gta9cl4n1DV28OXQfRNi/Jk/a0OPnHtWt/aOs/wDQB/8AJxP8KANeisj+0dZ/6AP/AJOJ/hR/aOs/9AH/AMnE/wAKANeisj+0dZ/6AP8A5OJ/hR/aOs/9AH/ycT/CgDXorI/tHWf+gD/5OJ/hRQBr0UUUAcz8RtR1bSfh1rN74dsP7Q1GODEVvtLbgWCscDk4Us2B1xWX4A1/xXqPgPSrnW/DQt7x4cMgmEXygkKdjZK5UA4Pr+Fddq//ACBL7/r3k/8AQTRpH/IEsf8Ar3j/APQRQBheI9Q1dvCuqh9D2qbKYFvtaHA2HnpV211HWfscONCyPLX/AJfE9PpVjxN/yKWr/wDXjN/6LNX7T/jzh/65r/KgDmPFEWu6/wCENY0eDRkhl1GwntUkkvF2o0kbKCcDOBntWTq2m65H4HvdH/4QnwnFpK28h+xx6m5iTGXyI/sYXIb5u3PPXmu+ubaC8tZbW8hjnt5kMcsUqBkkUjBVgeCCDgg1j2Pgfwnpl4l3pvhjRrO5QMFmt9PijdQwKkBguRkEg+xNAHzL8Ktd8Ww6LE+l+EdOW2+3WFsNdjgWxkKteQjyXmRCZUcgKwwxw2Tuxg+1anpz6LeQ67qHw28HtcPqNuGura833ImmuEjWQFrRcsHkDZLA985rrrrwJ4Rvrg3F94V0S5mKqpkm06J2IUBVGSucAAAegArVvdNsdR+z/wBoWdvd/ZpluIPPiV/KlX7si5HysMnBHIzQBgXFlNdm++0+F1k/tBES53Xw/eBQQv0xnqMGqCeGY1tJoG8N3UpmKM08+uSyzgoSV2zM5kXBJxtYYyfWu3ooA4c+GIzbLEPDd2rq5k+0prsq3DEgA7pw/mMCFUYLEYUDsKcvhm3S6inj8JbPKCYgTUysDFAAjNCDsZgAAGZSRgc8V21FAHI6PpMmgyPJpnhqVGdBGDLqrTeWg6Im8nYg/urge1a/9o6z/wBAH/ycT/CteigDI/tHWf8AoA/+Tif4Uf2jrP8A0Af/ACcT/CtesLUPFEWlapqFtqEHlQ2mnHUEn8zPmqpIkXGOCvydzneKB2uTf2jrP/QB/wDJxP8ACoAuq32v6fcXOmLawWwl3ubhXJ3LgYAFX9O1T7TbWIvo0s7+6tvtBs/M3smAu4ZwM7SwGcDrXL2vxDabRdU1aa30o2lj91bbVTLKuX2gzL5QEIxhictgZPah6OzEtVdHb0Vwl98RrjSdIs77UNJtpY7jUIrUzadqP2iDy3VmMqyeWpbaFJKlR9a2tP8AFa6h471Pw7FZsE0+3jla78zh3bqgXHYbTnPfGOKdv6+Vw2V/63t+Z0NFFFIAooooAKKKKACiis/X7e+u/DepW2jyRx381rLHbPKSFSQqQpOOcAkGgD5x+EXjv+1P2ltdmadpLbXvPjg/u4jO6I/giED6+9fT1fK3gz4F+LfD3xTtJY9Q09p9Ha01CYiRgJIpJJVKg7epELg/UV9U0AFFFFABRRRQAUUUUAFFFFABRRVHXJ7+18PajcaNbrdajFayvaQP92WUISinkcFsDqPrQBzvwl/5JD4X/wCwdF/Kuwrxr4Ma14+l+FumIPDGmzWsC+VZzXOovavLCANrbBDJkdRuyM46dz3f9qeO/wDoVdE/8H8n/wAi0AdVRWb4c1f/AISDwrpWs+R9n/tGyhu/J37/AC/MQPt3YGcZxnArSoAKKKKAOb+I/wDySzxX/wBgW8/9EPXSVzfxH/5JZ4r/AOwLef8Aoh66SgDlfih/ySfxT/2Cbn/0W1dVXK/FD/kk/in/ALBNz/6LauqoAKKKbHLHLu8qRX2sVbac4I6g+9AHL/Ef/kUI/wDsLaZ/6XwV1Vcr8R/+RQj/AOwtpn/pfBXVUAFFNiljnjEkLrIjdGQ5B/GqOsajLpttC1tbLczTTpCkbSeWMt3LYOOnpQBT8WeHk8R6Sts2pXmmyRyCSKa0upIMsP4W2MpZT3GR7EHmuK0jws3hrU/DH2iWR7q58RXDuv8AaU92gX7FelceaeCQeTjJ7k4zXReIdGuvFNlFaa94W0y9ghmSdEmvd4DKc94TweQfUEisxPB8+nappF34d8IaFpIsr43VwLW4EZnH2aeEL8sI6GfPPofWhaX/AK7A9UkdB4v0D+34dPjljtbi3hug89tdsVSRSpXcCAfnXO5cjGQOnUcnH4Wj8OeMvDP2LyI7JtUESrFIWe4ddPvd08vAHmMTgkZztBJ7Df8AEOjXXimyitNe8LaZewQzJOiTXu8BlOe8J4PIPqCRXP3mif8ACPeIfCzaJ4O0XSnl1d8iznWPziLG7wGKxDgAsc8+nfNNaX/r+v6+Q9TrPGFneXtvYpbG7a1FyPtcVjefZZmQqQCr7lOFYhiAwyB36Hzy80rxKPjz4HvtWzc6bYrdWUd8J0KzSNbzsrGMHKuUQbjtxlevSu38Q6NdeKbKK017wtpl7BDMk6JNe7wGU57wng8g+oJFYcnhx9H8R+HzoHg/RNKaO+kupfsk4j84LazxBTtiHQz559D60kO9tjrfEelanqVzZHTPEt1okUbN9oW3SFjKpXjHmRvghse2CfaodKnuNI1600G61S71pr21ubwXl2YVaIRPAnlhYo1BB8/OTyMd88Z+v+HH8UXFlNr/AIQ0i/ayZmiFxdiQfMpBBBhOR0OPUA9qzbTR7nQPG2ktofhXSNNh+wXyG3tLkRq7O9qS52xAZAiA6c59qFsJmz408PTazNazCx0vV4YY3RtM1aVo4HYlSJMhXG4YI5U9eCO+Z4Y02fQfG1nZywWVtHeaddzx2dhKzQWYje0UxpkDIJfdwFGe3ermv+HH8UXFlNr/AIQ0i/ayZmiFxdiQfMpBBBhOR0OPUA9qzbHR7nQ/HOnf2F4V0jTIo9Nvd1vaXIjVzJLa/MdsQ5HlAdO/tQtFYGdvq2uaToNqLnXNTtNOgZtoku51iUn0BYjmsfTNXt9Y8e3X9nTQXNpBpFvKtzBMHWTzZpgAMcYHkHnP8XtXJ69f+Idd1ZRYaVHaXEXm6fM0sE93C8bMNxVhEFVvlHzZIHOQan8L6Pr/AIa8c6xINOsp/wC0rG1KqLwp5YhaVBk+WdxIdcnuQT3wBaq4Pex2Or+MNF0K9FpqVzIk5QPsitpJepIVfkU/MxBCr1bBwDWX4f1O11f4iazeWEhkhk0bTgCyMjAie+BVlYAqQQQQQCDVLXPDWta1qX24QSWEmELLaaooVnjJMch3W7cqScDoe4NUvDNrrOi+OtYtodOiuZjpVi80lxqHzSM1xesXJEQGSS3AUAYGPQC21/r+v68h7/1/X9ff6TRWN9u8Q/8AQEs//Bif/jVS6Xql1d393ZX9klrPbJG/7ufzVZX3Y52rz8h7UAM07/kZtZ/7Yf8AoBrXrI07/kZtZ/7Yf+gGtegArxL4G/8AJU/iz/2Gh/6Puq9trxL4G/8AJU/iz/2Gh/6PuqAPbaKKKACsbwz/AMeN7/2Erv8A9HNWzWN4Z/48b3/sJXf/AKOagDZooooAKKKKACiiigArm/hx/wAks8Kf9gWz/wDRCV0lc38OP+SWeFP+wLZ/+iEoA2NX/wCQJff9e8n/AKCaNI/5Alj/ANe8f/oIo1f/AJAl9/17yf8AoJo0j/kCWP8A17x/+gigCv4m/wCRS1f/AK8Zv/RZq/af8ecP/XNf5VQ8Tf8AIpav/wBeM3/os1ftP+POH/rmv8qAMvxf/wAibq3/AF6v/Ktmsbxf/wAibq3/AF6v/KtmgDI8Vf8AIs3f/AP/AENa16ztfs57/Qrm2swjTuoKCRtqkhgcE4OOnpVf7d4h/wCgJZ/+DE//ABqgDZorG+3eIf8AoCWf/gxP/wAao+3eIf8AoCWf/gxP/wAaoA2aKxvt3iH/AKAln/4MT/8AGqPt3iH/AKAln/4MT/8AGqANmisb7d4h/wCgJZ/+DE//ABqigDZooooAp6v/AMgS+/695P8A0E0aR/yBLH/r3j/9BFGr/wDIEvv+veT/ANBNGkf8gSx/694//QRQBX8Tf8ilq/8A14zf+izV+0/484f+ua/yqh4m/wCRS1f/AK8Zv/RZq/af8ecP/XNf5UAS0UUUAFFFFABRXPeJNQ1iDVdI07Qrixtpb+SUPNeWr3CqETdwqyR8n1zWDrHj/UNJ8J6m62ttc69p8k0TRKGWFhEodpsZyE2svGSdzBc96Fq7IDv6K5S41HxDD4wtLNNR0l7CVHubiI6fIskFuoxky+eVLFiAPkAwGPapvC/ia58Qavq8clqkFnbGFrJud80bqTvb0zjIHoRnnoCudLRRRQMK57xT4Tj8TS6c7XbWv2SbMu1A32iEkF4T6Biq5PtXQ0UAc1d+CLK88Y2/iBr3UkkhjdTAmo3KoWLRkEKJAqqPL5QLtbOSDiuV1Oyl0nxnoOkXmuKuoajBcW+mT2dgIBEsZSZvPVW2ybtgXAEYOWwOePT6+WfjZ43On/tFaLPE8nleHfs/mKvcs3mPjjnKMqn6Yo2t5Due2r8NxcTNPqd5ZtLNcrNcR2Nh9nglVYpY8bDIxDES8uWOdoGOK0fC/g1/Dt0lzPqbX9wbUwTSvDsMrmQuXPJx1Ax7da6dWDqGUgqRkEd6Wjrf+trCeqs/61uFFFFABRRRQAUUUUAFFcvN43SN5ZotB1a40yEuJdTiSLyV2EhjtMgkYAqeQh9s10Ut5bW9i97cXEcNrHGZXnkcKiIBksSeAAOcmgDBsf8Akqeu/wDYF03/ANH31dDPuNvJsba207STjBxXD2dz4j/4W9rKrpWlm3On2CvIdTkDrB595tkC+RguQWymQBgfOckjtrnZ9km85tsextzegxyamXwscd0eYwzav/a2nw6rqjRa6zWq2USawgjlhCr58hhDDzQSr8lSfnXGMEj1OvG9HeBI0sJI9UFrJPYTSXdxYQgwwLhLc7llJAkMa8hSVw2VXOR7JWsv1/yJWwUUUVAwooooAKKKzNX8SaHoBiGuaxYaaZjiMXdykW/6biM0AadFVG1WwWWzjN3Fm+yLYhsiYgbiFPQ8c/QH0qhe63PNPPZeGY7DUtQtHX7VBc3jwJCrA4y6RSfNwPlwODnI4yAZPwl/5JD4X/7B0X8q7CuB+EGobPAGkaJqEtjBqljarG9jHclp41VEz5sbIrRuDIoZcEDK/MdwrrNXn1yHyf7B07T73O7zftt+9ts6Y27YZN2ec5xjA654AMLwXqun6L8HfC97q97b2NpHo1kHnuZRGi5hQDLHjrWtpHjHw1r941roev6bqNwqFzFa3aSMFBAJwpJxyPzrk/D2qw2PwJ0BdX03+0HbQYXbTbOZHlmt1jjUuA5TOFdCwH3S2AW4J6fQ9avdQvDDc+FNS0dBGWE909sVJyPl/dys2fwxxQgZNqXivR9KDfarmR3WbyDFb28k8m8KGI2IpbAVgScYAPNadrdQXtpFdWkqzQTIHjkQ5DKRkEV5zqMkR8aXn/CORznXPOnjdJL9YYlHkQ75OY3wcGPC4wSmTwDXaeFHtJPCOlvp0ckdq1qhjWVtzAY7nuffvTXw39A6/eUviP8A8ks8V/8AYFvP/RD1o+I3tY/Dd8+oQzTWywlpEgk2OQPRty7T3zkY65FZ3xH/AOSWeK/+wLef+iHqTx2HPgjUhGsbOUXasrFUY714YgHAPTofpUy2GtGeb69quq3Xw28QW8/i7Q7y3k0a6uI9OUrc3nkGJthM6SKrY4+byz6ZP3q9orw/xtoPiT/hC/EVxqGm6DaW+LzUZZLPUHlk+azeLYFMK55IOcj6V7hVvZMn+v6/P8ArzjWUs/8AhLb+7fxTY+D/ALNtFw1pdw/aLndgI8yyAxqOMLlWY/3h0r0evLWsNfuPE9xd6XpWg3cFlqtzIHvNQeKRy8ewgqIGxjPXJzio+18n+g3ovn/mdD44jMXgC0Rrt7wrqWlA3Mm3dL/p1v8AMdoC5PXgAV2NcBrun3Gk/CPR9PvDG1xa3ekRSGJiybhe24O0kDI/AV39VLdgjzGKG0Ot3lxH4ys/CYlujbHTtLu7d98+c/vBKrIJWByVRQfUtxjttfGF0sEkkahDye/WvM7fQ/E2qaXI1jpXh14J9PutPjnm1KRJCJJSfMK+QcEEfdyfrXpOtIY7fSEY5Zb6EE+pwaF8C/r+v+DboD+L+vL/AIb5X6mrezta2FxcRxNM8UbOsa9XIGcD61zGj+K7zVNQljkW1jtvKcxzoHONirmU5wNhZmUDg/ITnrjqLplWzmZ1ZlEbEhG2sRjscjB/GuE0XWoE1iaSxs9VtIbezkllW/vHmjuCFVgIyXddwHXBBG7GDzib737D7WNnRNemvdZS1TWNN1iFonZ2sYChgIIxuPmOMHJ44PHfmn+KP+Ri8Gf9hqT/ANN95VDwv42g1vWo7GHxBoWsNNbvOY9Mb57YqV4b94+4HdjOF5HTniPzNc8V3On6nZWunwQaPrN55ay3L7pvK+02ZziPC53F+/THvVNWJWp29ZGo/wDIzaN/23/9AFN87xN/z5aT/wCBkv8A8aqpcW3ia41Kzu/s2kqbXf8AL9qk+bcMdfL4pDNrU5/sumzzfa4LPYuftFwu5I/cjIz+YrzfVfE14PEunzxXqa3b2sMkjtotq4kcFk3RjDOCeFPUcZBxkGuzm8SGDwS2uXC29syx5fzZf3UR3bSxbA+UHknjiuOi1O38deKItHTxPZahHHZSu95oEgjZQzJmNhvkx9z15BxjjJWt9B9DqfA+vx+JLG+v7RrwWjXTLFDeqRLCQBvU56Ddn5ckjpx90Xpv+R6tP+wbP/6Niq3pGljR7FbRLqa4jTiMSrGvlrjAUBFUY/CuY0O88ReIbfR/FMFlpkMd5piulu93ISqzCOQZIj6jGKp26Eq5n3ms3w+Ig0qLUb6xhFyreQk1gxuQeSAhIdUPOScuQGwB1rrv+Z2/7h//ALUriLiTxWYbto4NG/skaqBPGZHNwH80ZIcjGN+MZXdt6fw10Oov4k06a6117PS3W2sXBhF3JyFy/Xy/bFJfChv4maEvimJNa/sdbOd9R3ZEQwFMOQPO3njbz0+9njHeoLH/AJKnrv8A2BdN/wDR99WNceGVuNQe9n0OA3TXy36ar5qBY0GOGU/NkJkYwQT82QTkbGnsG+KOuMpyDoumkEd/319QvhB7lKxuvEUXiSKDWIbyLSxNstJd8G6YkMcTEOSQAONoGerVs2P/ACOWr/8AXra/zmrm9MuNMn1rTZI5UlvmuJPPsW1GeSW1OGwxjZyBtHByoHzDB6A9JY/8jlq//Xra/wA5qF8KB/EO07/kZtZ/7Yf+gGtesjTv+Rm1n/th/wCgGtegArxL4G/8lT+LP/YaH/o+6r22vEvgb/yVP4s/9hof+j7qgD22iiigArG8M/8AHje/9hK7/wDRzVs1jeGf+PG9/wCwld/+jmoA2aKKKACiiigAooooAK5v4cf8ks8Kf9gWz/8ARCV0lc38OP8AklnhT/sC2f8A6ISgDY1f/kCX3/XvJ/6CaNI/5Alj/wBe8f8A6CKNX/5Al9/17yf+gmjSP+QJY/8AXvH/AOgigCv4m/5FLV/+vGb/ANFmr9p/x5w/9c1/lVDxN/yKWr/9eM3/AKLNX7T/AI84f+ua/wAqAMvxf/yJurf9er/yrZrP16wl1Tw/fWNuyJLcQNGjPnaCRxnHaq3neJv+fLSf/AyX/wCNUAbNFY3neJv+fLSf/AyX/wCNUed4m/58tJ/8DJf/AI1QBs0Vjed4m/58tJ/8DJf/AI1R53ib/ny0n/wMl/8AjVAGzRWN53ib/ny0n/wMl/8AjVHneJv+fLSf/AyX/wCNUAbNFY3neJv+fLSf/AyX/wCNUUAbNFFFAFPV/wDkCX3/AF7yf+gmjSP+QJY/9e8f/oIo1f8A5Al9/wBe8n/oJo0j/kCWP/XvH/6CKAK/ib/kUtX/AOvGb/0Wav2n/HnD/wBc1/lXJ/Ff/hIf+FZav/wiHl/2h5XO/bnys/vMbvlzs3de2cc4pPB3/Cdf8Idpn/CR/wBlf2n5A8/72c9s7PlzjGdvGc4oA7Kisj/ipP8AqF/+RK4bxd4XbxBqurTX0fhabUrTSIzIt7ost5IkJacxlHaVVTLCX7qk5GWyNooA9Qor5N8GaV8R9T8E2Nrr9ray+FBqOnLaDXrbzzGWuoo1MKEhimH2kEhSjMARk17BZ239g6RrFvZ2Wj6bd2nibSrGS40LT/sC3MTS2cmHUOxPFzIh+Yggnjk0AdV4zTSIzp19q/ir/hGZLaV/s9159vHvLLhl/foynj0Gaoaj4N8Eap4Nc6w1jfWk6uw1q7MMkm6U8yJMy7VJOMbQBwABwBV3xXdf2d4i8PahLa309tBLOJWs7Ka5ZN0RAysSswBPGcVyOqaHrOv2B0mz0RX07UdRudQe31Fnto1hChUViI3Ku0jeaEK54OcUl/X+X6/IP6/4P6fM7y00nQ7PWbqCJ4DPcWMUJsCU2x20e5VCxgcJlmB7dqzNE07wJ4Y1w3GiS6Lp91rcaCCC3aCITKuf9UqgFgc5OM8gVy9hpev3uqW+uXGnzx65pWjww7njZVuZI5ZVmiDEAESKAwPujVV0iPdpGjaNe6TqumPNZ2bX1ydIu5nkKMWSEMqFItrfeZiMZPH8Qt7+f/DhZJW9PyX5HqMWv6PPJeRwatYyPYf8fapcoTb/APXQA/L074pbHXdJ1SOGTTNUsrxLgMYWt7hJBIFxuKkE5xkZx0yK8yjgmttK05L3QdSvG0TTJLbUIhZzqLqdpYSgUquZVLIzkoGAGc9cVHceHdS8SajDc6XeX9rc3gvZb2aTS57SLeUt1SHbKqsqMqKCw5bD4IPRf1/X5/5lW1PWrW7tr63WeyuIriFiQJIXDqSDg8jjqMVNWb4euftWgWj/ANnSaYVjEbWbx7PJK/KVAxyoI4I4IwRWlQ1Z2IWqCvmH4gfAPxBq/wAQTqU2u2JPiLVpY4QyPmEeVLMobjoEh28e1fT1YOu25uvEvhkb9gtbya66Z34tpYtvt/rs5/2cd8hDLnhuwu9K8L6Zp+pTrc3dpaxwSzJnEjKoUtz64zWlRRQAUUUUAFFFFABRRRQB5jcw2V5rt95XgHxNcLBctHPHDqUUdpMx+YsYDdKjBgwPKc555rsfGen3Oq/DzX9O0+AyXV3pdzBBDkDc7RMqrknA5IHXFcvfaT4su5Ltbo3xkto5W017LUhEGmaZtjOAw3KqMnysCAEbgkiun8Yahe6P8O9d1G0mEd/ZaVcTxShQQsqRMwbBBB5GcEYpr4UD3/r+v6Z4pp/xm/4S74mfYdE0XVrS71GXSrR9rfNAlteySTlwvOwxylT7Bs8V9AajcrZ6XdXTxmVYYXkMY/jAUnH4145aeH9S8FfFjWtciudGuLm9bSRdiPS5IgVvL14JPL/0htjfJvJO7JxwMHPsmoTS2+mXU1tF500cLvHFj77AEgfiaiXwsqPxI8xS7kij0+2jt9ObTNLks5poBNPJ5ktxIdkcTGTGIwysFYMDxgJgY9Wrx3T7u3+0WM+j3WnNDZ3duIYbXT4FW+vZmP2jGF3KyRnqpBXB3E4Ir2KtZfr/AJGa1/r+v+HCiiioKCiiigArzHx/qOm6b4jmjur68T7TZpLd2sOiT3byRRMzAxTJ8sZycEnIGQfl616dXAeO74alet4YmtbdHuzDHa3lwsm2IyCUOwKMpyNqrhWB/eDJxSd+g1bqZupC0n+Hen20WsQ6bDqt3K/2jU9Inj2SMXkyiB42g2kEq5OOAc85ofw14z0XR/D+maJrVi2NQ5uLHTngXy/stwXec75Fbe+zDFcBypIY4FX7nxAI/Cek67e6Vdaoun3csQOleWInUK8PnHzXGIipznccZ5JHNc6+pabeWEVudFvPCGnapqzWNxcC8jCEJDcSr5SxyMgYyRIGUoVcPt+fIxel2kS72Tl/T6m74Xht7r4lR3drps8d1Y6bdWuqXkswuPMleW2aJROD8wxHKQnGzuq7hnU8Zz6pouv2PiWxs7Key03Sr5LyS9vTbpGHe2dcFY5GZiIWwAuOOoOAafhnV9dXxnYaLdW0cGi/2ZdzWsi2otTc7JbYKTActHsWUjqu4sTsXApvxO8PXHjq507wX/ab6bY31rc311LFFveTyJLdUj5IG0mcse+UX3zIzlvh9J4i8TeEPCOuaLFpyW2j6UNOCw37tNORLa+Yrq0SrH8ts/G5s7xg45rtvCuma5a6pbXOoNfZntXfUjcX3nRNOXAQRJuITADH5QBhgOT08i8FeCdR8L6f4bGmXWp65p/iLSDqd5o0EiQrw9mWA3OqtxJt5I+XI/iIr1PwpYSWfiqI6R4LuvC2lm1lFyjG2WKaXdH5ZCQyN8wAfnA4PWnHf7/y/r5g/wCvvMjxXOo1vXLvWdag0iysCq3TPp8EhFs8R2mN3jYvI7hkKEn5eAoyCfQ/DslzN4Z06S+ijhuGtkMkcahVU7RwAOB9B0rz7WLm30PXby+vBBqNpp99JdJbWcby3d3dyxEJDs27SUQschjgYyFAye68Hwm38F6REZI5dtnH80LbkPyg/Ke49KI/B935A9/v/r+vToVPiP8A8ks8V/8AYFvP/RD1N42itp/BuoQ30TTQSIqNCoB80lgAnzccnA545qH4j/8AJLPFf/YFvP8A0Q9bt7ZW+o2UtpexCWCZdroe4/p9al6oaPFPGtp4e07wx4k/s/wJo+nCGyubH+0bZIxLHdG1aRlUCMZTaSu/cDn+HHNe5V5n8TNC8NeHfhXqzyuls8dhdw2TXd65Ms8sbZxvY+ZKwBwTlsZA4zXfaVrela9atdaHqdnqVujmNpbO4WZFYAEqSpIzgg49xVX0X9f1/XqT1L1eV6jpGgT6teuPBWla7qWoarJDBNqKRr5jKhaQs2xyqIE2jgknsBzXqlYk/g/RbjUbq+e3lW4uo2jkaO5lQANgMVCsAjEAAsuGOBzU9b/10H0Oe8SXFpdfCvS5tNtFs7R77STFbKoUQr9ut/kAHHHTjjiu8rzr4ieIfC+j+GYtCGs6TZ3FnqGmf6A13GkkMa3cD8oTkAIN2cfd56V299relaXdWlrqep2dncXz+XaxXFwsb3DZA2oCQWOWUYGeo9aqWrYI8q/szwxb2MMkfgDSNWmkjuL+W4u44lke2RxmUnY2XYt8qE8gcsK9I1l0lt9Hkh4ja+gZeMcEHFRHwN4fP2wGyfbeMpmT7TLtIDbtgG7CoSSSgwpycg5qxr4AGlgDAGoQ4A/Gkvht/X9f16D3NWZlWF2kUsgUlgFLEjHoOT9K4rQIdOGqarNp0mkmyigPl2wjMbQ5HzCRCxKZCpnKjIArtpF3xsgZkLAjcvUe4rKtvC2k28ksz25ubmaJoZLm6kaaVo2+8m9iSFP90YHtS7j7HG+A4rODxZN9o07Tk1SW2JN1aWs0KrH8jeWitCqgYdCRuLHjOeMdL4D/AORduv8AsNar/wCnC4q/YaBDY3guTd3dy6KViFxIGEYIAOMAbjhQMtk+9UvBEbwaJeQyjbImsakzLnoHvZpF/NXU/jVPZEnRUUUE4GTwKQzlIW2fDV22WjnypMLeoXiJ3nG5VBLc9gMnpXLeBobK18drDFYWsF+Laf7XcW8MkfnkMi8Boo1CqVYALkDnPPJ7Tw9awar4FsUmDGC6hEyEMVYBm3owI5BGQc+tVotITTvG+mym6ubqaW0uVMlwy8KGjIACgAcsecZPcmhaNj6HU1zfw4/5JZ4U/wCwLZ/+iErpK5z4eI0Xwz8NQyDbJDpVtFIv911iVWH1BBH4UCE1F/Dn9sSSi2szrSjy47o2wLJLjCKZduA3IABOeferviDf/wAIXqnm/f8A7Pl3fXyzmuKvtSYeIZtOivZxbf2j5lxa+dACp81NowYi252yyruyVUnI6V23iuRYfBusySHCrYTknH/TM0L4UwfxW7HNzeKXaRrU6npccXnJZnTmU/aXUkIXD78A87gNh4HXnI1NNQRfE7Wo1yQuiaaoz7TXtc1LZ3Ta8ssrStawXIRbzD7IpGkTdkZ+8oURAgbQC2SOQensf+Sp67/2BdN/9H31C+FMH8TRLJq9rqu21WC5gjupAkF48Q8uZlO7A5z0Q4JAB7Zqax/5HLV/+vW1/nNXA+HrmCTx1a2a3LfabaUg6d9okcI4DmVtpchVQNGqnABLHrkY76x/5HLV/wDr1tf5zUdEwe9h2nf8jNrP/bD/ANANa9ZGnf8AIzaz/wBsP/QDWvQAV4l8Df8AkqfxZ/7DQ/8AR91XtteJfA3/AJKn8Wf+w0P/AEfdUAe20UUUAFY3hn/jxvf+wld/+jmrZrG8M/8AHje/9hK7/wDRzUAbNFFc/Pq2qzeLrzR9NiswlpY2100lwWyxlknXAA9PI/8AHqAOgorI/wCKk/6hf/kSj/ipP+oX/wCRKANeisj/AIqT/qF/+RKP+Kk/6hf/AJEoA165v4cf8ks8Kf8AYFs//RCVd/4qT/qF/wDkSud+H39v/wDCs/DHkf2b5X9kWmzf5m7b5K4zjvQB1ur/APIEvv8Ar3k/9BNGkf8AIEsf+veP/wBBFct42i8eT+C9Sh8MjTG1OSLbCFJBOWAbHmfLnbuxnjNJ4Hi8eweCdNh8TjTV1SOMrMHOWGGIXPl/Jnbt6UAdF4m/5FLV/wDrxm/9Fmr9p/x5w/8AXNf5VzfiP/hIf+EV1XzP7M2fYpt23zM42HpV21/4SP7HDj+y8eWuP9Z6UAblFZH/ABUn/UL/APIlH/FSf9Qv/wAiUAa9FZH/ABUn/UL/APIlH/FSf9Qv/wAiUAa9FZH/ABUn/UL/APIlH/FSf9Qv/wAiUAa9FZH/ABUn/UL/APIlH/FSf9Qv/wAiUAa9FZH/ABUn/UL/APIlFAGvRRRQBT1f/kCX3/XvJ/6CaNI/5Alj/wBe8f8A6CKxPiPBrlx8Odai8KTJDqrW/wC5dyB8uRvAJBAJTcAfUjkdayvAFn46t/AOkx69qGmveiD5zLbtI4UklAzK4BIXaMgdu/UgHUeJv+RS1f8A68Zv/RZq/af8ecP/AFzX+Vcz4ji8SDwtqvmXmllPsU24LaSAkbD0/eVdtYvE32SHF7pOPLXGbOT0/wCutAG9WbDpPkeKb/WjPkXdlbWvk7MbPJed927POfPxjHG3qc8QeT4m/wCf3Sf/AADl/wDjtcjrqeMY9S8STS6vp1rpsOhwuzz6fM8BIN0ZNh89VRwoXcfm4MeQMDIB6OCCAQcg9CK8zub/AMQaRr/iq90e70xbV/Emn2klvdWMkjs00FhCWEizKAAJAcbDyp5548P+F934zudAgs7fxRpf9kx6jpzR6ddTrczRn7fAqusSuHRFcpkEqCDgckEe+Q3Ph7SL/UNM8Y+KNHvtY1PWrS7NlbZt5EnAtkt1EPmvJ96GJ8k4wcn5c0AdP5Pib/n90n/wDl/+O0eT4m/5/dJ/8A5f/jtbNFAGN5Pib/n90n/wDl/+O0eT4m/5/dJ/8A5f/jtbNFAGN5Pib/n90n/wDl/+O0eT4m/5/dJ/8A5f/jtbNFAGN5Pib/n90n/wDl/+O0eT4m/5/dJ/8A5f/jtbNFAGN5Pib/n90n/wDl/+O0yLTdYm1qzvNSvLF4rUSYS3tnRmLDHUuf5VuUUAFFFFABRRRQAUUUUAFFFFAHkd1pF4bC8lPw81OfxKfOMOtrNaeYJCW2MshnDqgyPlwMDjHavVXW6fTmWCSOK7MRCPLGZER8cFlDLuAPUAjPqOtT0UbKwPV3OG0vw/qV/401ebxPfaffxLDYJ5VpYyW3z28z3EL5M79HdsjocL0AIbuGDFCEIDY4JGQDWTp3/Izaz/ANsP/QDWvQByWmWfj1pYpNU1jQUjWY+ZDFpMm5ow56P9oIBZeehxnviutoooAKKKKACiiigArzHxt4y/srxLPaSeMoNBMT2sKWrm3y8crYkm/eKTlRyD90Y5Br06mtFG5yyKx9SKOqYdDL8MzWt14egkstcOvwNuxqDPE/m/McjMSqnHTgdqr6j4O0W90dLGLTLCNLeWS5tY5LfdBHcOjr5jRqV3/wCsYkZHXIIOCN1VCjCgAegFLTe4HJeALXxDb+H7BNZ1iz1C1htRAmyykjnZkIUO8rTuGJCkn5Ryeoxg7+pWc88Zn0xrO31NEMcF3dWpnEasyl12h0Yhti8BhyFJzjFVvCv/ACLNp/wP/wBDatekBxvwqi1WP4beH21O8s7i3fSbM2sdvaNC8S+SOHYyOHONvICdDxzgdlXN/Dj/AJJZ4U/7Atn/AOiErpKAPNNV1HQtB8UXMk/jLQo57OSa5ttKvrlIGiuZVwTJJuJ24Y4GzI3Hk8V2vhW3itfCWlw295FfRrbJtuYSCk3Gdy47HqParw0+0F7LeC3T7RMipJIRyyrnaPw3H86sAADAGAO1C0Vg63Ob+I//ACSzxX/2Bbz/ANEPXSVzfxH/AOSWeK/+wLef+iHrpKAOA8ay69rmq6t4YsIY5NI/sqF79bdlS8kS4NzGyxNJmLOIVGGA+8TuHFbnhvxrY+KdXvrTS0cw2dtDK0rgqS7yzxtHtI/hNv8AeBIO7jpk4/jEaPe69LbT3i2V9aWsEskc8Ilg1CORp1jheNSHm2mOUhBwN+QCScbHhaaO9lnvbzS00rWGt4oJ7YThj9nR5fJfZ1RWLSkZVW6g/d4AOjrn/GlzPa6DbSWs0kLtq2mxlo3Kkq99ArLkdirEEdwSO9dBWbr2r/2Jp0V15Hn+Ze2tpt37cefcRw7s4P3fM3Y74xxnNAGb48/5F21/7DWlf+nC3rS17SP7b06K18/yPLvbW73bN2fIuI5tuMj73l7c9s55xiuN1kfDO21C5l1rwfG9w11smuZPCM8glmeTb/rRbkOWdgAQTuLDBOarXWn+FZraNfB3hKTT74ahpzySR+Gp7ImFdQt2f52hQEALuIz0UnGFJAB6bWR4g/5hn/YQi/rWvWR4g/5hn/YQi/rQBr0UUUAFc/eQXWhaxcatYW0l5Z3m031rCAZEdQFEyD+L5QAy9SFUqCcg9BRQBhr418MmF5ZNe0+ARDMq3FwsLRD/AG1cgr+IFU73UJvFUbaZoayrp8vyXmpMrRr5ZGSsJIBdmBxvHyrk8kjFO8Walpej6poF9rV5aWNsl5IpuLuVY0UmCTA3MQM5p3/Cx/BH/Q5eH/8AwaQf/FUAdFHGkMSRRKEjRQqqowFA6AVkX3/I5aR/163X84aqf8LH8Ef9Dl4f/wDBpB/8VVa28T6Br/jfTI9C1zTdTeKzumkWzu45igLQgEhScCgDra5rM/hO7nIt57rRbmVp828ZkeydjufKD5mjZiW+UEqSeNuNvS0UAeZ3PibS21aS5XWAZ/toWO+TW41tY0348toPNzuAypXyySxHPdemmafxdcwwx281vocMqyyyzK0T3jowZUVDhhHkAsxxuwAAVJNR65rei6B43sLjXdTsNMWXT51jkvLhIQ58yLgFiMnFTf8ACx/BH/Q5eH//AAaQf/FUdLB1uY17tg8USQJqD3FnLeRmSzaGaK3jlLA/NOqOhbOCEyoLEA8tWzY/8lT13/sC6b/6Pvqwpdf8DSzyH/hZGnpbyXH2hrVdVs/LLbg2ORuxkf3qv+HNb0rXviTr91oep2epW6aTp0bS2dwsyKwmvSVJUkZwQce4oXwpA92aNn4dvbe4s4pr+3k0+xkMlvEloVmzggbpN5B+8ckKCe/fNix/5HLV/wDr1tf5zVs1jWP/ACOWr/8AXra/zmoAdp3/ACM2s/8AbD/0A1r1kad/yM2s/wDbD/0A1r0AFeJfA3/kqfxZ/wCw0P8A0fdV7bXiXwN/5Kn8Wf8AsND/ANH3VAHttFFFABWN4Z/48b3/ALCV3/6Oatmsbwz/AMeN7/2Erv8A9HNQBs1zdj/yVPXf+wLpv/o++rpK5ux/5Knrv/YF03/0ffUAdJRRRQAUUUUAFc38OP8AklnhT/sC2f8A6ISukrm/hx/ySzwp/wBgWz/9EJQB0lFFFAGX4m/5FLV/+vGb/wBFmr9p/wAecP8A1zX+VRapZ/2jpF5ZB/LNzA8O/Gdu5SM479azorbxNFEkYvtJIVQM/Y5O3/bWgDborG8nxN/z+6T/AOAcv/x2jyfE3/P7pP8A4By//HaANmisbyfE3/P7pP8A4By//HaPJ8Tf8/uk/wDgHL/8doA2aKxvJ8Tf8/uk/wDgHL/8do8nxN/z+6T/AOAcv/x2gDZorG8nxN/z+6T/AOAcv/x2jyfE3/P7pP8A4By//HaANmisbyfE3/P7pP8A4By//HaKANmiiigCnq//ACBL7/r3k/8AQTRpH/IEsf8Ar3j/APQRRq//ACBL7/r3k/8AQTRpH/IEsf8Ar3j/APQRQBX8Tf8AIpav/wBeM3/os1ftP+POH/rmv8qoeJv+RS1f/rxm/wDRZq/af8ecP/XNf5UAS0UUUAFFFFABRWXrXiLT9A+zDUTdF7pikMdrZTXLuQMn5YkY8DvjFMl8V6LB4bk16e+WLTYgfMmkRlKEHaVKEbg2eNpGc8Yo3A16KwpfGOkQazFpcw1CO5mk8qNn0u5ETttLYEpj8s8AnIbHBqzoniKw8RQtNpYvDEoVhJcWE9urhuQUMqKHHuuR09aNwNSiiigAooooAKKKKACiiigArh9b1/V9P1HV9Hiuv9Nu5Lb+yJPKX90sx8tuMYbyyjuc54IzXcVQutD0291ix1W6tVkvrAOLaYk5jDjDcZwcj16dqFuHQwpPH+h3Gqajoml6tZ3eq2tqXiihuo3kmlxJmNUByXXy8lccZFYumeINUtbvSdNvtS1Z9Rmv4VvINUgtVYRPDMRs8lANpaM9TuG3Bx0ruZtH0+5nu5bi2WVr23W2uA5JWSJd2FK9MfO351mx+CdCjsZrX7PcOszIzSy307zKUzs2zM5dNuTjawxk4xmmtHf0/Mbt08/yOP8AFPjDXtK8RSLZ3ai0tdaijniaJTm1Fl50qg4zngsD17ZxxW14W8SalrXxB8R20s6vpFvDAbCNUAx88scjFsZOXjPfGAMVm2U/h8/FaXwQLJZfsWnjU1mmuJZZmncNDJvdmJf906feJ4PsK7PSPDWk6CVOk2n2cpbR2g/eO37qMsVX5iehdjnqc8k01ZL+v66fiweq/rualFFFSIyNO/5GbWf+2H/oBqvqGvakNZm03QNKgv5bSJJbprm8Nuqh921UxG+58KTg7RyOeasad/yM2s/9sP8A0A1z7XMeqeLrv/hFNeSyvJ4vJuludLllimETFS0MhZELqXKkguBxkcUAW7fxlcXfiqHSIrTT7fMUcksd7qXlXall3FUgEbB9oxn5x1pt548jgsNduI7HYdJu4bRftshtllaTZhiSpKLmQc4PAzWSbKzufEtvof8AwkLzRQ3EDutxpsjTSz24VgoveEZvk3MpDPgtyBwJ3uNPuta1a10vUp2vtTuobhHOiTXNvA0aqgEj7dmCYic7kODkEcGnp/Xy/wCCNWT1Ot0LUJtV0eG8uBY7pQSDp94bqEjPBWQom7/vn860K5TwPeac8V7b2uo/bbyWdru4kWyktopC/G+FXzmP5fvKzAnJySa6uhkq+zCiisTULTxVLfyPpWs6PbWhx5cVzpEs0i8DOXW5QHnJ+6MDjnqUM26KxvEc2p2tmLvT9Y0vSreEM1zJqNk9wpHGMFZo9vfrnORjGOcjR9Q8Z6lYufK05FfLQ391ZS22VIXb/opkdzzuJ3yRnoNvegDsKoa5DqFx4d1GHRJ0t9SktZUtJn+7HMUIRjweA2D0P0rIj0/xwkweTxHoUqZ5i/sOVcj0Dfajj64P0NY17qvjvS72U6ze6FYacXJivY9JmuYolzwJW+0oUOOrbdvuKAMf4VaP8SbTwLCmreINKVzNI0SXmnyXciJnoZEnjH3txxg4z97sOi1/S/iLceHr6HSvEmhpePAywmPR5YWDY4w5uXCn3KnHpT/DP9v6l8PPDd5o+oabZS3VhHdXIutPkuFLSor4TbNHtALMOd2eOmOep037d/ZVp/a/2f8AtDyU+1fZd3lebtG/Zu527s4zzjGaAPO/hx4a+JOheBbHTdX13R4JLZfLiguNOe6eGIcIhkSeMHAHAwcDAye3U/YfG/8A0MPh/wD8EM//AMmV0lFAHK3cHje1sZ7j+3/D7+TGz7f7CnGcDOP+PyuisJ3udNtp5du+WFHbaMDJAJxUer/8gS+/695P/QTRpH/IEsf+veP/ANBFAGP8R/8Aklniv/sC3n/oh637m5gsrWW5vJo4IIVLySyMFVFHUkngCsD4j/8AJLPFf/YFvP8A0Q9W/F9pJfeDdWtYYZZ5JrSRFihVWdyV6AMQCfYkUbAch44l8HaPrWoeJfEGs2cepR6PE1jbR3iW94FhaeTMLbwzCQuF242tswd2cDY8FaTrMWoXOt61q1jqyahptpFb3FpzuWN7hwSwAV8rOmHUKG5+VRjPDHWxqS30Oi6Hr+j2H2CSaaFrq2NsDh1w8O92j+ZeibTu+8MZJ9pp20uLyCs3Xzo6aQ03iO4t7bT7eaGdprmfyY43jlR4yWJAH7xU4JwTxznFaVcR4k+Is/h/VZ9Pj8K6rdyR+WY5Vlt44p1ZlXKFpQzYLYI28HGcA5pdbDDxN4k0PX/DcZ0LWtP1MW+s6T5xs7pJvLzqEGN20nGcHGfQ1a174haHYSRWOl67o9zqzana2LWP2xHlHmXUcUo8tW3blVnPsV5GARTPHc8lz4DtZpraS1kk1PS2aCUqXjJvoPlO0kZHsSPeuwoAKzdc0661KziXT7qG1uYJ0njkngMqZU9CoZScjI+8MdeelaVFAGNp+r3Y1X+ytbtkgu2RpYJoGLQ3KAgHGRlWGRlT2OQWwcbNYWvvG+teH7dBuuvtrTJjqkawuHf6YcJ9ZFrdoAKKKKACiiigAooooAKKKKACiiigAooooAKxrH/kctX/AOvW1/nNWzWNY/8AI5av/wBetr/OagB2nf8AIzaz/wBsP/QDWvWRp3/Izaz/ANsP/QDWvQAV4l8Df+Sp/Fn/ALDQ/wDR91XtteJfA3/kqfxZ/wCw0P8A0fdUAe20UUUAFY3hn/jxvf8AsJXf/o5q2awINF1iye4Wx1i2SGa5lnVJLEuV3uWIz5gzjPpQBv1zdj/yVPXf+wLpv/o++q39h8Q/9Buz/wDBcf8A47XPWVnrv/CzNaUavaCUaRp5Z/sBwR515gY8zjGDznnI6Y5AO6orG+w+If8AoN2f/guP/wAdo+w+If8AoN2f/guP/wAdoA2aKxvsPiH/AKDdn/4Lj/8AHaPsPiH/AKDdn/4Lj/8AHaANmub+HH/JLPCn/YFs/wD0QlVPFWjeNL/wrqFroXiK0t9QlhKwSLZtEQfZ97bSRkZwcZzWb8OfC3jXw54FsNJ1vX7Np7VTGifZTN5UYOETfvXdge3HToKAPQaKxvsPiH/oN2f/AILj/wDHaPsPiH/oN2f/AILj/wDHaANmisb7D4h/6Ddn/wCC4/8Ax2j7D4h/6Ddn/wCC4/8Ax2gDZorG+w+If+g3Z/8AguP/AMdo+w+If+g3Z/8AguP/AMdoA2aKxvsPiH/oN2f/AILj/wDHaPsPiH/oN2f/AILj/wDHaANmisb7D4h/6Ddn/wCC4/8Ax2j7D4h/6Ddn/wCC4/8Ax2gDZorG+w+If+g3Z/8AguP/AMdo+w+If+g3Z/8AguP/AMdoA2aKxvsPiH/oN2f/AILj/wDHaKANmiiigCnq/wDyBL7/AK95P/QTRpH/ACBLH/r3j/8AQRRq/wDyBL7/AK95P/QTRpH/ACBLH/r3j/8AQRQBX8Tf8ilq/wD14zf+izV+0/484f8Armv8qoeJv+RS1f8A68Zv/RZq/af8ecP/AFzX+VAEtFFYWr+MtH0PUJLG+N89xFbrcyraaZc3IjiYuFZmijYLkxv1I+6aAN2isObxjosXh2x11Z7i406/8v7NLaWU1wz+YMp8kaMwz05AwSAeTirWka9aa3532KHUIvJ27vtum3FpnOcbfORd3TnGccZ6igDM8UR6hDreh6lp+kXWqpZyTedFayQq6h4yoP72RAeffNcj4i8D+Jdb8M6nLay2trNePdXI0m4gE2XkQImJBKqq4VTz8yhnJ5wDXXeKJNQm1vQ9N0/V7rSkvJJvOltY4WdgkZYD97G4HPtmuU8SeN9R0fwrPZNrtnZaqupyWEGqXoiSN1jTzSzA4TJX92cADceAOlJNJ3/q11+tg6/P9H+lzqk0rVLnW57nUUSRbXTFt7Vkby1kmfJmYDLFPuxgZyRz1qr4I03U9Ommils9R0/TI7aKKK11G9S6fzVyGdGV22pt2jGV6fdXvkw+O7258RadqVvOj+G7jSLe5uI9g3QvM7qJd3XClQrDoAc9jVe08QeI7vStCvI9Yaa9ure3kj062t42+0gt++knJTMaBehVlGR3JAq9U3f0/Fitp935I9OorzWy8Q6/NZ6fdNrMaDXNMlvh9rjjSPTdjRk7SqZICSH75b5lHIBNUrnxt4j0OWBgL3WLKUXbW0s9qiSTRIsJE8qoi4RS0v3VBZQOCSDSs9mXyu9j1eiqWjiT+x7Zp9Q/tJ3jDm6CKolzzkBRgDnj2xyetXaGrOxCd1cKKzY9Y8zxVcaN5GPJs47rzt/Xe7rt247bM5z3rMPiyW78T32h6Np6XM9ra+cs9xcGKGSQOFaPcEY8ZGWAPPGODhf19w3pv5fjt+Z0tFcC3xFv7eErf6ZpNtcvcyw27PrJW2kWLAkcytCpGHYIBtOW9BzXbWFy15p1vcyQPbtNErtC5BaMkZ2kjjj2p9LgWKKK5u+8UXtjryW0mkY05ruOyF3JOVkkldQQY4tmHQZwW3jGG4ODS3dg2VzpKK5vxH4nvdDuJGi0j7RY20aS3VzJOYuHYqFiGxhI4xkrleq85NdDMhmt5I1doy6lQ69VyOooDrY+RdG8c+Z+1idbMim3u9UexDKeGiYeShP5Ifwr69r51sv2bNDHjm+0+LXtUj+w2dpexTIIw2+WW4U/w4wPIUj6mvoocAZOfegAooooAyNO/wCRm1r/ALYf+gGub0hNXXXJr/UfCuowtaLMlhBDJZpbRoz87dsxYyOACWYADkYHOcLwz4Q8aWvxf8Vapd+LM6ZOx8i2y0u0OwaMbGwq7EG3IyfzNeg/2drP/Qe/8k0/xo63DocrPb65c+ILmQ+Gb2JbSWd9LMT2i2olZWX7RIRN5jO25v4BjdyCeaqXWjz2niYaNoRure92W2bhdVjMItVUI5kti4fcwSQA7G55DryB0l7ourRLPeXXjXWYIhg+VZWVoVQYA4VoJHJzz1PWuA0+w1TxTKdetW1LW9Ou7C0mRtSgthKkhDttEXkxI4UODvSRWz0JzR0sO7vc67wZp2oNe6bNd2n2WLRdMbSjIs8ciXUgdFZl2MSFUwkYbawJIIGK7mvOvBHhTXE8Ljz/ABNrukM99eyCzjgtdqK11KykedDJJ8wIb5nY/N1rp7bRNbtVdD4qurwFtyvd2luXUYHGY0QEZBPTPPWm5N7/ANa3JSS2N6sTwlp91pmi3EF9F5Ur6nqE6ruDZSW8mkQ8HujqcdRnBwak/s7Wf+g9/wCSaf41yNnF4gvfCerazP4z1eOa1udRRIbe3sljC29xNGgG63ZvuxjOWJ60hmuLuz1TW4tU1meKPTob37FpMEp+We4BIaXB6tuVlT0Clh94Y66uCtvhy48OWtrL4h1K++yWWywS8S3K2s21dkylIlYspXqzHqc881Be6h4p134eaprVvqEvh6V4na2t2s1MsGwANuJJyS6vgj+EjHqQDVuPGF1afEPUNBWwuL5Y9Otrm3jtYCWLvJMr75CQijCJjcR3xmr7adrusoRq14ml2r8G00875GHcPMw7jsigj+8a53RbldL+Mer2ms6vDNd3Oj2IhaQLCZSJLnIVc8nvx6130NxDcqzW80coRyjGNg21gcFTjuDwRQBzeh2Ufg/Ubbw9bGT+x7iMjTVllLm3dFy0G5iWIKguuSSNrjoBVjwDcz3nw28NXV5NJPcTaTaySyyuWeRjCpLMTySSckmpPFisNKtrmIhZbbULWRGIzwZkVx7ZRnXP+1+FWvDmr/8ACQeFdK1nyPs/9o2UN35O/f5fmIH27sDOM4zgUAaVFFFAFPV/+QJff9e8n/oJo0j/AJAlj/17x/8AoIo1f/kCX3/XvJ/6CaNI/wCQJY/9e8f/AKCKAMf4j/8AJLPFf/YFvP8A0Q9auuy38Hh++l0ePzb5IGa3TAO58cDB4rK+I/8AySzxX/2Bbz/0Q9WvF81zb+EdQksvtPnLFx9lRmlAyA2wKC27GcY59KTdkBwGrrqj/wBqaz9muoJdRE9tc20mnLGi2sSMY5Gl2h92WXqxB3MAOCR6zXjKT6ZPa60JG8XPJEsqab/aEeorAsPkg/P5gCE7jJzJlunP3a9mqtkv6/r/ADFe7YVx2vP4j1DV5rFPCei6jp9s0U9vc6hqLx7nySCFEDgMrL2PcetdjXnGuaRDc61qs+q3OlanpNnI9zPY3jvtgleKNY94CsBgpnP8IkJx0qepRr+O2uX8B2rX0UcNydT0syxxSF0Vvt0GQGIBIz3wPpXYVwnia1ksvhbpdtNdC7kivtJVp1YsJP8ATbfkE8ke5ru6qW5K2CsvXrm6t7a2SxmWCW4uo4fNKb9oOckA8Z4rUrI8Qf8AMM/7CEX9aQyTS9Ei06aW6luJr6/mULLd3JBcqOigKAqr7KAO5yea06o6hrNjpjol5MyvICVRI2kbA6thQSAM9elW4Z4ri3SeCRZIpFDpIpyrKeQQfSgCtqOq2OkxxPqNykAmk8qLd1d9pbaAOSdqsfoDVT/hKtG/5/P/ACE/+FYHiHxBpd3r/hiSyu1u47HVpJLqS1VplhX7Hcx5ZlBA+d1X6sK6zTtUsNXtftOlXtveQbipkgkDqGBwQSOhB4I7UAUv+Eq0b/n8/wDIT/4VNaeINLvrtba1u1eZgWVCrKSB1xkVSn1+9g1e8tI9HnvIoWQJJDLCnVQSD5kiknJ7DFTagc+JNFJGMifg9vkFAGxRRRQAUUUUAFFFFABRRRQAVjWP/I5av/162v8AOatmsax/5HLV/wDr1tf5zUAO07/kZtZ/7Yf+gGtesjTv+Rm1n/th/wCgGtegArwX4Rarb6R8R/izcXO5i2tqkUMY3STOZ7rCIO5P+JOACa96rwv4I2dvL8YPindywq89vrDLFIRygae53Y+u0UAeialrOoaUtq+t6nLZ3N6WMVjp2lS3zIByR+7VmOARlsAZ6VE/iONdPt7xPE80yXJcRRW+jvLOxQ4ceSimQbTw2V+U9cVW8UXsOqeJ9IfTdW1C0SxNylxeabaiYoxCrsy8UinkEHAJBHasmSW18L6mLzQrXXNSjmspbeVre0xdRzPKZWnHnIsZLMxJ7fKvykcUl5j6HRw67HcX2m2cPi5GuNUSV7RPsA/eCP8A1g9FK55U4PXjg1a068n1a91C007xOJ59NmEF2osQPLkKhtuTweCOma8zf+2ZLmz1S4tL241HSxdz2jSWQR5GM8LojGOJE3OiyKWCgZJyehPV+BLi38Py6o1/Hdq940MzyLYzESzGPMp4TP3y3WqsrX/rfT8Cetjsf7O1n/oPf+Saf41ztlYasfiZrSjWsSDSNPLP9lTkGa8wMe2D+ftXQf8ACV6V63n/AIL7j/4iuesvE2mj4ma1MTd7H0jT1H+gz5yJrwnjZkfeHPfn0NIZ0f8AZ2s/9B7/AMk0/wAaP7O1n/oPf+Saf403/hK9K9bz/wAF9x/8RR/wlelet5/4L7j/AOIoAd/Z2s/9B7/yTT/Gj+ztZ/6D3/kmn+NN/wCEr0r1vP8AwX3H/wARR/wlelet5/4L7j/4igB39naz/wBB7/yTT/Gj+ztZ/wCg9/5Jp/jTf+Er0r1vP/Bfcf8AxFH/AAlelet5/wCC+4/+IoAd/Z2s/wDQe/8AJNP8aP7O1n/oPf8Akmn+NN/4SvSvW8/8F9x/8RR/wlelet5/4L7j/wCIoAd/Z2s/9B7/AMk0/wAaP7O1n/oPf+Saf403/hK9K9bz/wAF9x/8RR/wlelet5/4L7j/AOIoAd/Z2s/9B7/yTT/Gj+ztZ/6D3/kmn+NN/wCEr0r1vP8AwX3H/wARR/wlelet5/4L7j/4igB39naz/wBB7/yTT/Gj+ztZ/wCg9/5Jp/jTf+Er0r1vP/Bfcf8AxFH/AAlelet5/wCC+4/+IoAd/Z2s/wDQe/8AJNP8aP7O1n/oPf8Akmn+NN/4SvSvW8/8F9x/8RR/wlelet5/4L7j/wCIoAd/Z2s/9B7/AMk0/wAaP7O1n/oPf+Saf403/hK9K9bz/wAF9x/8RR/wlelet5/4L7j/AOIoAd/Z2s/9B7/yTT/Gim/8JXpXref+C+4/+IooA2aKKKAKer/8gS+/695P/QTRpH/IEsf+veP/ANBFGr/8gS+/695P/QTRpH/IEsf+veP/ANBFAEl/ZpqGm3NlKzLHcxNExXqAwIOPfmsxNE1OONUXxLe4UAD/AEe3/wDjdbdFAGN/Y+q/9DLef+A9v/8AG65/VrDUtQutX0eDxXri3NtpqXDRQ21kI5RKZlUZaFm3ZhYHGOCuOc47mspYNOtfEmpambsC8awt0uYTIuIoY3nZH29RkvKMng7OOhoA8E+F/wAIfHvh+yt73UNXuNKtpbuCRtJi2yn/AFikyODlFIAB4yeMHFepPBrWsW+uabJdyam+m+JtN8kyLFGUgjNjcyfdCg43SH1OMDsK6tPEmjy6PBqtvqENxYXE0UMVxA3mKzyyLGi5XPV3Ue2ecYNcBqceq2+r+Kr/AErxFqGmbvE2m2bQW8Vs8ZE0WnxO/wC8hdt22Q45xlRx1yAd9rXh3T9f+zHURdB7Vi8MlrezWzoSMH5onU8jtnFFh4b0nTZreaytNkttHJHG5kZiBIwZySSdzMygljkn1rP/AOEX1f8A6HvxB/340/8A+RaP+EX1f/oe/EH/AH40/wD+RaNtgLlr4U0Sz+0i3sVC3UTQzKzs6tGzu5XBJAG6RzgeuOgAqla/D7w/YS272EV/afZ4ooY0ttVuok2R/cVkWQKwGT94HOTnNee/F/wJ4kvtG0iSx8d6s2zVLeApciGMBppUiSQGCOM5UvnnPGcYPX0CPwrrCRIrePPEDMqgE+RYcn8bYn9TQD13JZPAfh6WK7je0n23Yw4W9nXyxvD4jw/7oFgCQm0EjmrVh4W0vTriKeEXk80IkWOS8v57plD7dwzK7HB2Lx0GOOpqn/wi+r/9D34g/wC/Gn//ACLR/wAIvq//AEPfiD/vxp//AMi0AbOmaZaaPYJZadEYbaMkpHvZgmSTgZJwOeB0HQYFW65v/hF9X/6HvxB/340//wCRaP8AhF9X/wCh78Qf9+NP/wDkWgBdS0HWn8UNrOhatYWhltEtZYrzTnuMhXdgQVmjx98jkHpVWw+H9jpHiB9V0m7vIHNpJAsMl3cTRq7vuLhXlIxnJ24xk561wnjvwH4luPiN4Mubbx5qxikvGgBmWJXhZI5JmZVijSM7liK/Mp7Z3Dgeif8ACL6v/wBD34g/78af/wDItK36/iD138vw2/IrTeCWhsNFGl3tvFfaRbPbJcXlmZ0kR1USEoHU7iVBzu7nOc0zR/FXhHw9oVnpa+ILcw2cS28c0rYExXC4RsbXOeMLn0qW+8FahqOn3Fld+OfETQXMTRSqsdihKsMEBltgRweoIIqDxr4Sutb/AOEdi0mK3WHTb6KRld2T7OikESJjqyhSoHTDnPHFVd6gaUXjnw5cSyRW+prNND/roIoneSH0LoF3ID2LAZqjaaNfah4oTxNZa5pV/p84VrUPYPK0UJUZEUonCDdyd2wk5wcgCm6R4a1Kz+KOta7P9nWxuoFSJ4z+8mJEYCyA/wDPMxvtwcETHjirEfg27tZLj+zfF2t2NvNcSzi2hisjHEZHLsF327NjLHqT9aXW4dLEN/4X1++1uy1CTW9LmFrGoWC60mSRFkBJaVALhQrEEAEhiuODya66ub/4RfV/+h78Qf8AfjT/AP5Frgv+FceJ/wDhd/8Aa3/Cfap9j+w792IvPxjZ5ezy/J27vmz5f4bvno6WDrc9DtoFT4iajcAtum0q0RgemEluCMf9/G/St6sbR/D0ul6jcX13rmo6tPNEkOb1bdQiqWIwIok7seua2aAKOtamujaHealJG0q2sTSeWpwWwOme31rkYvHd3cNNBq1va6PbLJJZT6hb6kkrWs6xNIXAePb5aqM7m6EcpgE12Wpw3FzpV1DZG3W4kiZYzcxGSLcRxvUEZX1GRXj1r4P8RalNrekzWXhzTJjoMtkDBoJt0UyrKiiO4EjfJnDHAPHVFNEfis/6/r+vMfw3X9f1/Xluy3lx4P8AiOYNX8WalcRanBbpZLcw2rrcXLNJFtlWGESIgLW+GG1dzEFjnFbtj4x1DVtTTSLLS1ttRtmQ6m11JiK3Un/lmRzLuAO0gAf3iCNtc5HoqXcZ0XwuE1jTJr23u7vU5ogWLQTJLteckC53eWseRkqDli2MVyWgQ+Dj4wtLTSxZzeKoZ4jPo50K1igtmDKZCkqxAjaMkESseBwelOOsrf1/XcJaRufQNRWtrBZWcNrZwxwW8EaxxRRqFWNFGAoA4AAGMVLRSAKKKKACsbTn07XPD97FYW32a1luL21kTy1XMizyRyvgcHc6u2ep3ZPJNbNUdJ0qDRrKS1tWkdJLq4uiZCCd00zzMOAOA0hA9sdetAFbwtfSah4ZspLkKt3HH5F0ikkJNH8ki5ODwynnuMGm+L/+RN1b/r1f+VVr+K68P6rNq9hA91YXRB1C1hTMiMBgTxgcscABl6kAEcghtMPpviTRJFiljvLC7jaNmhkOGB4I3Kcg/kQfegDnWg8P6j8SNY0+9hN1dXelQJPBcoj28kcbyEqFIyWHnqWzxiRPWuL0j4M+J/A+tTan4E8as4nfdNYarAWhn5yd5Q9f9oKCOfWu11rwvcaZosb+C0c6pDcmRXu7uSVpfMXynLySMzNtUq2Cf+WSgYqHU/DnhvQrSH+0dU8QvNKfLhiXxFftNcvjO1EE2WbAJwBxyeAKAHtrTeKvCvhRhGbafXWtb5oY33+VEm24fJIHy/KqE46yD1rofDn9l/8ACK6V/wAI9/yCfsUP2H73+o2Dy/v/ADfdx97n15rjPgt4Z/sn4e6JqF1IZLi506IwqZGdYIXAk2ru6Fi2444+6vRQa67wnpU+g+C9E0i8aN7jT9PgtZWiJKMyRqpKkgHGRxkCgDXooooAp6v/AMgS+/695P8A0E0aR/yBLH/r3j/9BFGr/wDIEvv+veT/ANBNGkf8gSx/694//QRQBj/Ef/klniv/ALAt5/6Ieukrm/iP/wAks8V/9gW8/wDRD10lAGN4v/5E3Vv+vV/5Vs1jeL/+RN1b/r1f+VbNABXKvYeJ9KvbuLQ4NJu7K8uHnMt5cSRSQF8bhtVGEgznHK8YHbNdVRSsBw3ivTP7G+GWnaaJfN+y3+lReZtxuxfW/OOw9u1dzXK/Ef8A5FCP/sLaZ/6XwV1VU3d3AKyPEH/MM/7CEX9art4vtE15tOe0vFhWYWxvyi+R55UMIs7t2cEclduTjOeKjudTi1nRtA1K2V0iu7uCVFkADAMCRnGeaXS4FfxIdZXXo/8AhF3s4702w+0G+crEYtx2hcKTvzu56DvngVS0aKHxZbrpzxyHQLCGKOeCbreTsgdkkwNrIqumQPlZmIPC4O34gfw8txCNc01L+coTGo05rt1QdThUYqvv0z71X8CLANEu5LIxG1l1G5eAw/c8vzCEx2A2gYx2oWwPf+ux0ccaQxLHCixxoMKqjAUegFYut6I0jtquiKkGswrlJAdq3IHPlS4+8p5AJyVJyPfcooA8q8Q26+LNQi1WHS7fUNLFtFLcRy6WjtESobErGZHfCkfIoIAzkEkCu31K5gg1nQpnkRYSJQGAwOUAGPzFcXHNpf2O+W9lgtbmKWUQ28t9LANQHnudpRGAkH8A4Y54IIOD0fjIW8yaYL22Z4XWTNtkDccLhDkEAE4B9s0LSIP4l/XY6+iub8MwwWV9d2n9iadpdz5aSs2nSeYkiEsAC2xDkEHjGOQc9QNO88RaNp939lv9Vs7afj93NOqNz04JpgaNFFZkviLToL77JO9xFJvEe+S0lWPcTgDzCuzkkDrSA06KKKACiisyDxFp1xfLaK88czsUQT2ksSuwycBnUAnAJwD2oA06xrH/AJHLV/8Ar1tf5zVs1jWP/I5av/162v8AOagB2nf8jNrP/bD/ANANa9ZGnf8AIzaz/wBsP/QDWvQAV8+/Cezv9S+KfxTsrW4+yWcutH7ZPG5E20T3OI4/7pbJy+cgDjkhl+gq8C+EusQ6P8Sviu8iPPcTa4I7a1iwZLiTzrohVH4EkngAEkgAmgD0C8vrnT7jU9OtNVi0PSdOntoleKFDJDE0OdkKlGDOz7RhgeCcDOKNOv8AxJrN5ZaLeajc6PKti95Lcx28P2iZfOKRAq6MiHYAzjbwWAGK5zxDoEerapcNqus+JodbN7EfsXh2aCBTMYGKiKSQBvli3AszqDgnAyBVSfRItSt9Ns7DXPiJqk8cE0iSW15YR3Vsqy7JEedwkjfOMFQ7A7R2Aoj/AF9z/wCHCX9ff/S/LY2tT8a63pGsSaWL+C+X7NGj6lFArW9kxuJI2mm2/wAQAQFc43A/dAOPTLWN4bSKOW4e5dUAaaQKGkP94hQBz7ACvHPsEFlDaNpV34zv7XVoRpyPBFo4STBkZoXSVFIYHzdxK8nPJruNJ8H6naaPaW8HjPxNbRxwqqwTrp8kkQA+6zfZ2yR0zuP1NPp/X9f16A/iuv6/r+up2Fc3Y/8AJU9d/wCwLpv/AKPvqP8AhF9X/wCh78Qf9+NP/wDkWufs/DmqH4k6zEPGmuK66TYMZhDY73BmvAFP+jbcDaSMAH5jknjCA9Eorm/+EX1f/oe/EH/fjT//AJFo/wCEX1f/AKHvxB/340//AORaAOkorm/+EX1f/oe/EH/fjT//AJFo/wCEX1f/AKHvxB/340//AORaAOkorm/+EX1f/oe/EH/fjT//AJFo/wCEX1f/AKHvxB/340//AORaAOkorm/+EX1f/oe/EH/fjT//AJFpr+GdVjRnfx7r6qoyWMOngAev/HrQB01Fca9k0dtFcSfE7VEgmhaeOVjpoV41GWcH7NgqAck9AKqLcWD6X/aSfF26aw83yftQn0sxeZ/c3/Z8buemc0Ad7RXLNoGoK8KN8QdcDT58pTHp2ZMDJ2/6LzxzxUv/AAi+r/8AQ9+IP+/Gn/8AyLQB0lFc3/wi+r/9D34g/wC/Gn//ACLR/wAIvq//AEPfiD/vxp//AMi0AdJRXN/8Ivq//Q9+IP8Avxp//wAi0f8ACL6v/wBD34g/78af/wDItAHSUVzf/CL6v/0PfiD/AL8af/8AItH/AAi+r/8AQ9+IP+/Gn/8AyLQB0lFc3/wi+r/9D34g/wC/Gn//ACLRQB0lFFFAEc8KXNtJBJnZIhRsehGK5yHwlqkECQxeOfECxxqFUeTYHAAwP+XWunooA5v/AIRfV/8Aoe/EH/fjT/8A5Fo/4RfV/wDoe/EH/fjT/wD5FrpKKAOb/wCEX1f/AKHvxB/340//AORa5rU/B2vQap4jv28Ua9LbyaLDGksdvZSSXLI10zRbFt8nAdSNqhiZCMtgBfSaKAPlX4X/AAt8Tpah21PW9KuTd2dw2mDTpoECJdQs0jyXEYhLoAzhBuJ29xlT7pbNpfh2/u9MvI/EHiG+1DU7e4mmuNGaSMS4gRJPNjhSALGI43JzlShPLDFdtRQBQ1vWrPw/pE2p6mZhawAGRoYHmZRnGdqAnHqccVS0bxbp2u3jW1lb6pHIqFy13pVzbJgED70iKM89M5qTxU98nh+b+zYjK7MiyhYRMyxFgHZUPDkLkgc59D0OD4R1HUrjWPKTUNa1PTzE5mm1rSxZPFICu1U/dRFgctn5TjHUdCR1YPYufEL/AJAWm/8AYd0v/wBLoa6quV+IX/IC03/sO6X/AOl0NdVQAVyXj++u7W00yHT9S1HTpbm9CNNp9vHMwjCs75V0fjapxtBOcds11tc54yl1Gzs7PUtG0SLV7mynMgjkunhMSlGVnAVHL4DH5cZ9MnAoDXoO8JopgmuIfFtz4kikwFaY25ERGc48mNOT3znp2q3P4q8P22sLpNzrmmxai5wto92iyk+mwnNYfw+1O816PUdWvtK0a1Mk7QpdabOZWnCOww5Man5exzzk8LXK3x1BUv7KxhuZfCUr3Bu77+yYZHTLuZSrmcMwB3YbyWPH8XWn1QLqXfHNrNBPpfiCHxjqc9vZ6rM32e1+ws8X7uaFkt1MGZHVm2FGLNgOMFwDXf6HrVvr+l/brSOaKP7RPblZ02OGileJsjt8yHGecYyAeK8003S/+Eb1O8k8JzDWPEkl3cyzWqr58CQzXDyxiSZsfZj5cikgNydzBJDyfRvDekyaNo7W08iySy3dzdvtHCGeeSYoPUL5m3PGcZwM4CYlqjVoqtqGoWul2T3d9J5cKYBIUsSScABQCWJJAAAJNZuheL9H8RyPHpk8wmj3bobm1lt5PlIDYWRVJwSAcdM0bjNuiis7/hItF+3W1l/a9j9qut32eD7Sm+XaSG2rnJwQQcehoA0ayP8Amdv+4f8A+1K16yP+Z2/7h/8A7UoA16KKKAMjxWqv4R1RXvBZBrZx9oIJ8vjrgcn6DmvItS1VYtP1TWdL48QW8F/eTalHptzvjVbd2it5DJEFUAkHZIcAKnyktmvYvEOly6z4furC2uEtpplHlyvGZFRgQQSoIyOOmRWJ4f0DxVpesXFxqOu6VdWt5cG4uIYdLkict5aoArGdgo+RTyD3/Bx+LUHtY4u+D+IrdP8AhGI20vSrXVNPe+0kyb7jZ9sjO9rcf8eigIZM5BIVtyLgkWtPvvD9zLYaIPiF4YutNhlhW1tbaKJbt2RlKL5glIJJABKxgnPGKl8Mx6rqXx08cxy+ItQjh0v+zUjijhtsSxMks3lOTCTtUyOAQQ+G5YkAj0m1060sYvKtLeOJN7SYA/iZixP4kk0lo7g9izRRRQAUUUUAI7rGjO5CqoySewrzLTn2T/6BrnizSNJ1O7nuLO4aDTmtpXmd5mCbonlUEsxXzAM8DPSvSbm3S7tJreXOyZGRsehGDXCTeGvFt1BpWjXf9jNo2nGMNMJpTPceWP3bFNgCchSyhznnBFLX+vxDp/XyL8usza/oY1h7vXPCFhDEJhOwsGF0jgFThhMRjHA+Q/N0PbOx4efRdDvZNU1SPUte2fZr6J47e8mMoyrSpEFifYGA+ZGAwOCeuj4W8K3mkSXzSWem6XDNapbpZ6bM7xOy7v3zbkXDEEDGCcDlm4xPb+F72Lwh4Z0ppYDPpL2jTsGbawiADbTjJ6cZA/Cr0v8ANfdrf9CXflfez++2n4k9t4Vvomxc+Mdfu48EeXKbVPTndHArdvXvVTTPAA0nW31K08SayzyS73SdbWYum7d5RleAylO2N+QO+ea66ipKPLfhFHqviX4JeFpz4i1DTZYIZYC1lFbHzEjlaOMN5sL/AHUjABGCeScmvSdNs/7O0q0sftNxd/ZoUh+0XUm+WXaoG92/iY4yT3JNef8A7Pn/ACQnw9/28/8ApTLXpNABRRRQBT1f/kCX3/XvJ/6CaNI/5Alj/wBe8f8A6CKNX/5Al9/17yf+gmjSP+QJY/8AXvH/AOgigDH+I/8AySzxX/2Bbz/0Q9dJXN/Ef/klniv/ALAt5/6IeukoAxvF/wDyJurf9er/AMq2axvF/wDyJurf9er/AMq2aACiiigDlfiP/wAihH/2FtM/9L4K6quV+I//ACKEf/YW0z/0vgrqqAPLPEuoWcHibVYbrVdA0JZ3SOW11dZmbUAFUiVAJkVTk7QyqzZUc8AV0tqiR+EfC6RWb2MazWwW2dmYxDaflJb5j+PPrWLrujW93rmp3OrT6TqulWMr3UtlesxW3leFFj3/ACsBgoTnsJCcdK6D7LJZeG/DdtNdC7kiuLdWnViwk4PIJ5I9zTj8FvT+v6+QPf7zP8Z3N5ba7D/Zt7PY3E0CRrIuzYw8w7mO5G4jXcx5Gcgcdau/DYY8FxD5uLif7/U/vG5PA/kPpTPFkkVvq1vJqWlzanZPDsRQD5cEmSd7E/KuRj5iQRjjOapWulXFjpuh/wBn+Irwx6hdfvWtpo5Y33xyOSjshJywB3Z5pR+Eb3O7orG/sC5/6GLVv++of/jdY2t2eo2GseHba38RaoI9Q1F7afd5JJQWlxKMfu+DuiX8M0CG6Lrk9rpFz9m003UNhPcvcyGUIw/fSNhFwdxxzyVHPWptWNvbLox1iNbyERTeZGU8zzcqMLg9SSQOa5XxLo9np2sDTpFs2Mo3xS3RszNcZ3fKPNwSzSuM8bdowME10/jOCWWHTYjFvfy5N6xZG0BV3MuCDlRkgA9hS+zcf2ki3ocNmusFbLQf7Blij3TwGKJDKrcI2YiytgqwwTkenIJreJ9S1L7TeWtr5j6dHBi9eGySQwKw5+Zpl3HbzhUbA7E4Bq/D1Wlur68WSWeOZRh5J3lEXzvtiDM7ZIQqW9GJHsMT4geHI9X8Usq3nirTlniT7TdadJP9mwONqxxqQzkcEtwB69Kb3SCO7PUIFRLeNYiWRUAUk5yMcVyF9NLcapLLcT30ukx3iwyRfaIlG8OoGEEe8oGxn58nB4I69hCoSFFTO1VAGRzjFeVazpukD4nQ3GoWa2f+moY5E1KHfdy/LjcjyAqoyp2qu48cjoXvNEr4D1iiiuSuPF5i1N9PF3ZpqK3ojTTXjbz5YMhdy/Nz137wCoHB5yQt3YfS51tcZYTS3Or2Vzfz31xZT3DfYxLcREB8MVZo0jUgYBx8zdRkA9OzryfQdN0i2+J8cstmun3Pmyi1t4tShl8w/NukcGQvnhhtVfl5znsL4kD+FnrFY1j/AMjlq/8A162v85q2axrH/kctX/69bX+c1ADtO/5GbWf+2H/oBrXrI07/AJGbWf8Ath/6Aa16ACvDfgfbQv8AF34q3LxI08WrlEkKjcqtPcFgD2B2rn6Cvcq8C+Emrx6T8TPit+7a5u7jWxHbWsf35n8664HoB1LHgDk0Aela3oPiX7dqc/h+WzC6jcQtKHvHtpPKSLayrIsUm1iwHIHTOCDghkGieItL1CwvdH0fRUEVg9pLaNqswWImQOGWT7OTJnGTkKck9etSX0txpMto3iPX9QtWv3YNNaiFbS3cLkR5ZSwBAIBPUg9CQKzjrdxK1gmnf8Jdfy31u91HHEbGNliVgodvNKY3blIHXB5A6ULy/rR/pcJWtr/Wv+Zq2ng+5s9N0K3S4hklstUk1G7c5UO0glLhBg/xS8A9h1rrq8+TXPtVvaNpV54o1K4uUkkNpb/Y1khWN/Lff5m1eH+XCsST0yOajvdcu7W40+OCHxjeJqWFtZIjYIHbyzIVKyMjKQFbO4Dkd+Kev9f15Be/9fP9T0Wubsf+Sp67/wBgXTf/AEffVZi0O6khR217WImZQSjtBlT6HEZGfoTWBZaJcH4ma1H/AG7qYK6Rp7GQGLc2Zrzg/u8YGOOO59sIDuqKxv7Auf8AoYtW/wC+of8A43R/YFz/ANDFq3/fUP8A8boA2aKxv7Auf+hi1b/vqH/43R/YFz/0MWrf99Q//G6ANmisb+wLn/oYtW/76h/+N0f2Bc/9DFq3/fUP/wAboA2abI4jid2DEKpJCqWJ+gHJ+lYVzpf2ONXu/FOowI7rGrSywKGZjhVGY+pJwB3qteLZadDcS6h42ubWO1Ki4ee6tkEJYZAYlPlyOmetJ7AcZZ6Ff28OtG90u/ittbtJDYJbQGWTTYi5Z4ChICs27zMcc5TnaoN6G91P+2rbVtVg1bU9FtRcW1u8ukyLcuZEiwzwLGGABWRA2xeG54+Y9Bc3GlWWmQaleePZLexuMeTdS3lqsUuem1ymD+BqWVbKC9tbOfxtcx3V4N1tA91bB5x6opTLfhT8vl/Xnb/ME9eYydH8PXdjc+Bpbu3uDdWdk8Fy292SEeTwpGdoOeM9TjrXfVyyfYJLm8t4/G9w09iu67iW6ti1uPVxsyo+uKfbxWl5pJ1S08aXU+nhS5u4rm2aIKOp3iPGB35pt3dxJWZ01FYq6HO6Bk8R6qysMghoSCP+/dL/AGBc/wDQxat/31D/APG6QzZorG/sC5/6GLVv++of/jdH9gXP/Qxat/31D/8AG6ANmisb+wLn/oYtW/76h/8AjdH9gXP/AEMWrf8AfUP/AMboA2aKxv7Auf8AoYtW/wC+of8A43RQBs0UUUAFFFFABRRRQAUUUUAFFFFAGT4m1WfRtDkvLWNGcSIheUMUhVmAMjhedqg5OPTqOtcPZ+NsapbXb3mg+Kn8yK0F/o8bRfYxPcwQlWYvKOfMDY3Any8Y7j06szXV0pdNiGtAC1+22uzAb/X/AGiPyPu8/wCt8v29eM0LRgzkfH/h7UH02K5PivWBG2t6cY7YRWflwlr6EDafI3HZuyNzHlRu3DIPTeJbXWZVsLjQL+4glgvbfz7aNYTHcQGeMTbzIpYbYvMI2Mpz6nAqDVvC13rEAgufEN8IVuYblESGAbWilWVOfL6BkX6ioddk1TQdGjuE1ie5kl1PT7fMsMQ2pJeRRyAbVH3kdhnt1GDzQB1Fcd8QLgwrpqznWFsmeQynSI7hpN4TMefIBYLu9eD3rsaKTV0NaHD/AAzuri50om/1TX7288mJriPVtNNqsMhBLCM+THv5zk5boPXnJuYbK812+8rwD4muFguWjnjh1KKO0mY/MWMBulRgwYHlOc8816dRVt3lclaKx5DplxJr19Np1qW0fWv7T1GKDWrmQrJIiXdxtjhUcXAjRcbGO1Qv3SBXoHg3TLzSPD8lrqQPnnUb+bcSpLpJdzSI3y8Dcrqcds4wOlZ/izw5Y6x4m8Py3smoKwuJFUW2pXFuq4glIYLG6gN8xG4fMQcE44rpdPsIdMsI7S2e4eKPO1rm5kuJDkk8ySMzHr3JwOOgqRnP/EZmTwbM0dytjIs8JS/f7tifMGJyOhCdcHg9+M1x3w0u5b3xNFJd6tb6tcm2neVYlKyWzl0Bll7EygKV4UBVAAPLV6D4svbzT/DdxPpd5YWl4CqwvqC5hZywAQ/MvLE4Bz1I61Hotp4ngvGfXtW0q8tymBHZ6a8D7uMHc0zgjGeMfjTjpf8Arp/X9WFLp/X9f15mxdBDZzCUEp5bbgpwcY5xXlfhPSoNWlhSLxFAljNHazLplxpqw3ypFtMXzl8EHaMsqYPOMHJr1aZd8EiBQxZSME4B49e1eW2Oq61d+ItF8Man4O0CFLMFkgur95pYY4SgWaMtBg4BBBBOTwSpBoj8X3fqN7f15HfahqTnX7bQIjJA9/p91cLeRMu+AxNCg2qylSf3+QTkDZyDnjD0Gxv7T4mapDfa/qGqx22kWrxi7jt1wZprgN/qok6eQuP95s54xsava2N7rdrbrf3Gn629lcfZLm2VTIkAkgM2A6tHywhHzKTg/Ljk1mx+B72LVZ9STxt4gF3cQxwSyeVYfMkbOyDH2bAwZX5Ayd3PQYQF8z6lpfiDW77UZribQ1srea2RYlkMUoMwnVFjXzG+VYWw27ljtPYQ6P470fXbq3g06HVj9pG6KWbR7qKIjGc+Y8YUAjoSeaoi712x1PXtKtb6bWJ7LRrW4tTdxwh5JpJbsMT5aop4jjAHA+UdySaHh3UNSGuW1tY6hr19b+ZsuoNU0ZbOG2jCNjy3EUeSCFAAL8fnRHV2B7XPQaKKKAPP9a+EVjq/izUvENt4o8UaNd6n5X2lNJ1BbeN/LQIvAQk4A7k8k+tVv+FN/wDVR/iB/wCDz/7CvSaKAPNv+FN/9VH+IH/g8/8AsKx9d+Hn9iz2NvF4y+JuqXN87rFDZ69CG+VdxJMuxQMe9ew1z3iTT9Yn1XSNR0K3sbmWwklLw3l09urB028MscnI9MUgPKbvw0ltaQXEPiT4sXay3AtJFi122VoLgvs8pw7r82ccjK4IO7FXLjwV5Ephj8UfFW5nhiSW8ig1uFjZhgSA5JAZsAnbGXP5jPef8IpqEmlr58tqL6fWYtUugjN5ahXU7FOMnCIBkgZPPGasXel69Ya3qN34dXT5Y9U2NK15M8bW0ips3qFRhINoX5SU5HXnh9PP/gL9b/cJfF5f8F/pY4WDwJpd14gg0a2+JvxBlu5rM3mF1vhIwUA3fJkE+YCBjpnpVCTwxpf2q/tbLx/8S765srmO0EUGtIDcTOCdsZcKpxtbJJAG088V6fL4fvZvEFhey3xdYNKnspbgYSZpJGiIkUBdo/1bH2JHFYGn+Btc8PSal/ZWrtqUFzFDClvfzLbs0aoysPNghVo2+YYcBj1zychu1v67v9A1/r0/z/rqcWvheO6ktotJ8UfFbUp54ZJXig123RoNknlur+YyDIcEfKWHHWtSD4fQy/b1m8d/Eq2m0+3Se4hl1xCyhkLbQVBBI2kHnGehNaH/AAr7XbVtOeCOC6W3tpoTCniG8sDFvm8xV82GMtMAONz4JPJ5Nbk+g+IopbxtNh01l1Wyit7kXN/MzWrojLuVvLJnGG/i2EkcnnhSvyu2+v62/r8QXxa7f8N/XT0OJfwhpkeqaFYP8Q/iSJdchM1u39sArENu4CQ7flJ5A65INbl38FTcWU8K/Ebx2TJGyDztY8xORj5l2jcPUZGfWrF98NtUuZJ7q312SC4tltU06BBH5LLbANH5pMRcEyF87GHBHWvRRnaN2Acc4qnbp/S6CV9L9vx6nlP7Num/YfgvZXH2iSX+0Lqe42P0iw5i2r7fut31Y16vXm37Pn/JCfD3/bz/AOlMtek1JQUUUUAU9X/5Al9/17yf+gmjSP8AkCWP/XvH/wCgijV/+QJff9e8n/oJo0j/AJAlj/17x/8AoIoAx/iP/wAks8V/9gW8/wDRD10lc38R/wDklniv/sC3n/oh66SgDG8X/wDIm6t/16v/ACrZrG8X/wDIm6t/16v/ACrZoAKKKKAOV+I//IoR/wDYW0z/ANL4K6quV+I//IoR/wDYW0z/ANL4K6qgDzXUfF8HhbW9Q0218QeEtk1080q6nqv2ee1ZwCVaMK2/nkcpwQPet6G3t7Twr4ZgsbuO9t457YR3MRBSVcHDLjjB7Y7V1JhjY5aNSfUqKrajpdtqlqlvc+Yqo6yI0MrRsrL0IZSCKForf1oD3uY/iHQZ9V1OKZtL0vVbZISiwalIQsbEnLKPLcZIwM8Hj3ps1rPY2Xha1vHDzw3iI7By4JEEo+8eT9TzVXxHbR6BYw3ENv4k1UyzpD5VlqbblLHAJ8yVRjJA69/SsC5gn1DXvDUV5p3iXR0fVmQ/btUD+aPsV0/y+VM+MFFPOP50LbT+v6uD3uen1zfij/kYvBn/AGGpP/TfeVk+LrGTSYLFbDVrqzN3ciFry/vrh4YflJAIWReWICj5hye/APLtOdV8f+HdKupdQt5ra9X7TC1/OzxSm0vw21i33SIlKsACVY+pFC1Dpc9E1LQb66ubz7Df20FvqCBLpJ7MzPjbt+Rt4A+XswYZ59Qa3iXTPt13pNhG4XKyhTINwO1VOGHcHGCO4Jqn4jtP7HWzi086ne3d5MY445dZmhX5ULt83zc4U4GOT6da5dZZtR8V+GLa+i1XTLia83+X/bM0rG3ks7pwr9Cj7oVJXkccE80LayC/U9E0rTruLUri/vo7SCSWJIRFaZKkKWO5mIGT83THHqc1keJPBza5d3BkttPvIrkDm9VibciNkG0AHeBuLAZXDEnPTFDxda6poUdvPo1td6hasSLma4165hFt6MQquSvqe3U8ZIxfCZ1TXNY8Py6vdXVtFqGk3t0I7HWriWOXZJaBH524OJHGOeD15o3+Q9UeqQx+VAkZYtsULuPfA61z1x4WuJr9il7brZPMZmVrUtONzrIyrJvwAWReShIA4PTGD4ulXw5NFFFPqbCeBjHNLqNxsSTzI0G4hugDsxGQSEOKztCjvb3x9BpOoaxe3CW9pfLLPZX1xHDPJG9nghWkYgp5sikbjzn6BrX3hbKx6nXE3fg+5vvGX9qXukaFc2sM6S2/JjlVh/y1fEZ3uOoBYAcd+ai8SzWfh25ihMurTNJBJPltYljGFKqACW5O51z6Lknpg5vhEXGt+N9fsNSutQt206ysQ0Ftrk1xEJHa4LMr/KTlRGDlQcr+NJb3QdGj02ubs/C1xbahbM97bvZ2jKYlW1KzMFDbFeTeQceY3IUE5575w7u21C38V31raLqWoWNpawStFDqsyXG5zJkrucKw+QfKSp9z0o0O1TVvGmqQ/bPEEFrFpllKlvdXtxE6O012rnaW7iJOehAGKPMPI9ArGsf+Ry1f/r1tf5zUf8Izbf8AP/q3/gym/wDiqs6bo1rpc080D3EktwFEklxcPKxC5wMsTgDcfzoAg07/AJGbWf8Ath/6Aa16yNO/5GbWf+2H/oBrXoAK8P8AgdDG3xa+K8zRqZU1jarlfmUGe5JAPodo/IV7hXiXwN/5Kn8Wf+w0P/R91QB6V4v8NS+LraHSLqRI9GkJe92uRNIVwY1XjAG75ic5+UDHJrNHgu/1XVNMuvEt2xNlYS2kkmm6hcWrTMZEKufKKHBVMlSSATxnrXa0ULT+vkD1/r5nnZ8C6lb6Tp1mdO0bWI7ISxxJd3MkDwAyMVdJ1id9xQqGBxkjO4nrtw+GdQSHwstxercyaPO0lxLK7FnBhkjAUnJYguvLHJAyea6mimm0KwVzdj/yVPXf+wLpv/o++rpK5ux/5Knrv/YF03/0ffUhnSUUUUAFFFFABRRRQBieMU8/wreWo0+TUJLpfIjgRTy7HCsWH3FB+Yt2xmuHh0y90rw/aWeqxauupabqbTT61YWjXLTSNG2J/K2OZFZW2FQCUPTAANek6nI8Wk3kkbFXSB2Vh1BCnmsfTvDsM+l2ksuoaszyQozH+0puSVBP8VC0/r+v69AOOAvoo7DUbiHU9OmRrsQ31ho0konWR1JE1nsd4y+A2flOVOSN2KZd2t42l6bZpoU1nqEzWbzxw6dM8VwkMm5EWUMUtdpySH9cDPWu9/4Rm2/5/wDVv/BlN/8AFVj+JZfDXg7S/wC0fEviDUbC13bFZ9RuGLN6Kqksx+gp32/r+vy8g8/6/r8fM4/UNJ1O80/TLC102+W60aaWXUnazdVuozcI7IjkYlMgG7Ck9MHBOKi8b2Wu6n4P8VX2l2ax6NeySXDwXzS2k8gW3jQMI2iJ5dWO1thJVecGu+0a00TxFpMOp6Jreo3tnMMpNFqcxB9R97g+x5rl/i78PbPXPh1eJJruoWQtWW533F280bFcjayu2Od3B6g4+hXS39dP8ik7HW6R4fuP7Fs/t2oajBceQnmxR3hZUbAyASoJ/IVc/wCEf/6i+qf+BP8A9apfDmkJ4f8ADGm6RFcSXSWNrHbrNIctIFUDJ/KtKm3d3ISsrGR/wj//AFF9U/8AAn/61H/CP/8AUX1T/wACf/rVr0UhmR/wj/8A1F9U/wDAn/61H/CP/wDUX1T/AMCf/rVr0UAZH/CP/wDUX1T/AMCf/rUVr0UAFFFFABRRRQAUUUUAFFFFABRRRQBBe3trptlLeahcw2ttCu6SaZwiIPUk8CsW/m0nxhbf2bpmtWcs1rd2d7ILeVZmURTxzqCobgMI8A++eelR+PnEXhlZP3vmreWxg8qATESeaoXMZZd65xkAg46c4rM0zQPD+s3IbS9SVbSCKVDaWEslrcRSySiSQvIjiRPmA+T5ccg5BwGtf68gegvjrw7pa6HBKtrh31nTAx8xuQ1/AD39Ca2b+20Tw9p6zzWHmQzXlpDsx5n717hEibDnA2yOrZHIxkcgVj+JdBtNE8Ox/YptQl87WtJ3fbdSuLvGNQgxt85229ecYzxnoK0h4C0TzoJJZNYuPImjnSO5129mj3xuHQlHmKthlU4IIyKQHSUUUUAFRzzw2tvJcXMqQwxKXkkkYKqKBkkk8AAd6kooA4afxRpHiXV/CV34f1OC8iXW5oJTbzq+MWV3w20nglFYZ7YNaXjW71S1hsP7EuYYrqaWSJIpZ1j85jDJsC7uGIba2PRTXD+JzJb+J8aZqmoRw6TdSXVvaRGLJm8mTztm9PmDNeQxDnAaRueMDp/FA0/S9D8PSeNbma+W1kWOdl057n7XK0LR8rEp25ZsjjGcAUmNaalC50ebT9PnGsDVm0lZLKdorjzNUklnWTzJQqJvYIeFP8IIJAx10fB2paDfaq3/AAjU+vR23lNi1urK5jtFwwB2GaMBSCMbVYDr8vHGRZeJN+j3v/CE3WsC6N2lpb22u2Mzxq25gQhlMbdAScyHaFHyg8HU8JReI9A18aDr19Y3Nk8Ms9pJb2DRGVi4ZwWMzY2l+hXkEEHg1a/r7iWtf6/rudjfvcR6bcvZIJLlYmMKHoz4OB+dcInimxubPSLbSPEUl94ggliE1kdpmkDsvmiaLaDGACTnC7cD6H0OkwAxIAyepqVo7j6GLq/hax13W7W71WG3vLSGyuLSSxubdZY5vNkgkDHdx8ptxxg8nPGOeWs/APg9viTrNq3hPQzbx6TYSJEdNh2KzTXgZgNuASEUE99o9BXZavoNprfk/bZtQi8ndt+xalcWmc4zu8l13dOM5xzjqa87XSo1+P8AJ4eW81QadJ4PWR1GqXPmsy37FWM3meYSN7AHdwrFehIoA61rnSfDI1ax8OaDDDdaZpkNz5NpbLEkkbyXGxBsGeHSZiMcbyRksaxNI8TnWPE1hBNq/hzxIy3DFYtMt3WbTj5bjzGJkftlDkIfm/Cut0bwxpug3VzdWH2x7i6SOOaW8v57p2VC5RQZXYgAyOcDH3jWsFAJIAGevHWhaO4dLC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUV5h8QdNsNV8UCWVdWSDSbYXWqT2d3cp5ifN5VtGiOFLu2SSBkAAZBYEAHQ/CnT7XTPhH4XgsY/KifTIbhl3E5eVBI559XdjjoM4HFddXi3hT4fvFr+lWQGoWT6ay6hqATUrpobYHmCwjDPtcKAC7HJwo6Bxj2mgAooooAp6v/wAgS+/695P/AEE0aR/yBLH/AK94/wD0EUav/wAgS+/695P/AEE0aR/yBLH/AK94/wD0EUAY/wAR/wDklniv/sC3n/oh66Sub+I//JLPFf8A2Bbz/wBEPXSUAY3i/wD5E3Vv+vV/5Vs1jeL/APkTdW/69X/lWzQAUUUUAcl8TJ4bfwbG9xKkS/2tpvzOwUcX0BPX2BP0Brra8y+Ong218XeDbEXV1Pbta6naohjOQRPPHA2VPBIEmR9Pc10Vn8OdFsrGC1ivPEBSCNY1P/CQ3y8KMDhZgo6dAAPQCgDq6K5v/hA9I/5/PEH/AIUeof8Ax+j/AIQPSP8An88Qf+FHqH/x+gDpKw/EUKSal4dkYZeHVN8ZyeCbedT/AOOsw/Gq/wDwgekf8/niD/wo9Q/+P1k634I0qK80YLd66RJfhTu8QX7YHlSHjM3B46jnr6mgDuiM9a5rxQP+Kj8Gn/qMyf8ApvvKX/hA9I/5/PEH/hR6h/8AH65/xH4K0uHXvCaJda4RNq0iMX1++YgfYbpvlJmJU5Ucrg4yM4JBAO9u7K1v40jvraG5SORZUWWMOFdTlWGehB5B7ViajpdiPF2jTpaxJKbia5Z0XaXlEDRB2x94hHZec8H2FN/4QPSP+fzxB/4Ueof/AB+sq/8ABGlJ4h0mMXeu4fzsk+Ib8kYQdCZsj8KAO5rktTnhh+Lfhq3WSNGbSNRUR7gCR5loQAP+AE/8BPpVn/hA9I/5/PEH/hR6h/8AH65PVvgVomq+PNO8SNq+soLNVDQNqE0sjlSSpE7uZEGT0U/TBOaAPUK5K9uoh8ZNFtjNGJP7Cv2EW4buZ7XnHvsb/vk+hqz/AMIHpH/P54g/8KPUP/j9cnc/ArRJ/iNB4r/tfWV8qPBtzqEzSM20qCLgv5oGD03fjjigD0PVNH0zXLM2mtafa6hbk58q6hWVc+uGBGai0zw9pGi3Ek2kafBYtJBHbstumxPLjZ2RQg+UYMrnIGTu56DHnWk263kuky6hY6pbWGrzPDbSW/jTUpplIV2BeMlABhDkhjjI69aTzdIury9tNKt/EE8sd3DaWbT+K9QijumdWYvuEjFUHltzg5xwORkB+f8AX9WPWMc571zdj/yVPXf+wLpv/o++rlhFoZstLk2eJmmvr82EiR+JNRaOCRZDG+ZPNxgMpxnBb27dto3hjTdBurm6sPtj3F0kcc0t5fz3TsqFyigyuxABkc4GPvGgOtjXooooAyNO/wCRm1n/ALYf+gGtesjTv+Rm1n/th/6Aa16ACvEvgb/yVP4s/wDYaH/o+6r22vEvgb/yVP4s/wDYaH/o+6oA9tooooAKKKKACubsf+Sp67/2BdN/9H31dJXN2P8AyVPXf+wLpv8A6PvqAOkooooAK5bxd4sn8OTRRRW6MJ4GMc0obYknmRoNxHYB2YjIJCHFdTXK+MdV1fT7i0Gj6tpenxeXJLdm+s3nZY1wA6BZEJ+Yqu3kkuMUuoyfQdVu7+w1WDWLm3kewma3kvrBGijfCAsVUsxVlJKn5jyv4DL8P6p4vmlRIbKC/wBI8xRFf6nMbO6eLjLeUsbBiOcE+WT/AHR1NrRtXvdS8Gapc3Wp293cxpKA0Gny2DQHy8hXjldmVuc5OOCOO9cFpOhXjXNncWHgG/sm3WLWt6ZrXbbYcNcSDbMSPMXOdoJbvVx+Oz8vxJeyt5no3iuLQLuWG01/Ubmzb7NPcIItSuLONolMayF2idVIBkjGGJ+8cfxVlfDDVZToieG7+3vVv9Hs4DNd3MrypeiQyL5sbSYk2l4pOGVQBgLlcU7x7pWhy6xousa/NMHs1mt7CG3ysrXMrRMrJIGAUgQsuG+UhyCccGx4ZsNQs9R1a+1y/judVks7eJYN6GWO2jaYxNKEAG9nebJUBTtwPukmRl67tTqXi6a1mu7yKGGxikVLa5eIbmkkBJ2kZ4Uda8Y/aK8KwXkOj29nqTi9h8yRV1PWbdI2RsA4+0TqwIKjlVIOeTwK2baxe3sYdaXxfaTX/kRyNZi51QyOR83k5OoHPJIwVIyTx2qX9pbxlrXhrwjZaZoyiO31oT297cmPdtj2qDGMggFg7c9flOO5ABX+BPgnS28DXFtc6jqD3kdyXnOm+IisKllAAUWlyV6KOXAY59AK7Lx/8JrTx14Z/so61qVoyzrMkstw9yuQCMFGbB4Y9wQcfQ4fwj+JXinxN4DjvdZ8Manq1xHO8IvrI2kSTqADkrJNGd2SQdq7eOucgdx/wlGr/wDQieIP+/8Ap/8A8lUAN0XwNaaNoVjpkep6tIlnbpAr/wBoSruCqBnAbA6dBwOgq7/wjNt/z/6t/wCDKb/4qqn/AAlGr/8AQieIP+/+n/8AyVR/wlGr/wDQieIP+/8Ap/8A8lUAW/8AhGbb/n/1b/wZTf8AxVH/AAjNt/z/AOrf+DKb/wCKqp/wlGr/APQieIP+/wDp/wD8lUf8JRq//QieIP8Av/p//wAlUAW/+EZtv+f/AFb/AMGU3/xVH/CM23/P/q3/AIMpv/iqqf8ACUav/wBCJ4g/7/6f/wDJVH/CUav/ANCJ4g/7/wCn/wDyVQBb/wCEZtv+f/Vv/BlN/wDFUVU/4SjV/wDoRPEH/f8A0/8A+SqKAOkooooAKKKKACiiigAooooAKKKKAMbxXp2oaloDxaKbQX8Usc9v9tR2i3o4YZCMp6j1+oNc34ITxHfeJtS1DxL9h3W4FumNGa2mUlEYhZDI+5M9cFgTyDxiug8XRXMukReRFczwJcxvdw2rESyQg/MFwQTzgkDkgEc5xWfo99/bPi4ajpFpqltZm2dL1r62ltllcFfL2xygHcBvywGMcEnjBHf+u2/6A/6+/b9Sz48/5F21/wCw1pX/AKcLeukrm/Hn/Iu2v/Ya0r/04W9dJQAUUUUAFFFFAHBeMPB/hm78V+F7i68O6TPNe6xIt1JJYxs1wPsN02HJXLDcinnPKg9hXQai0Fm2l+HrLTbQ2t2GiMDqFhit41G5VQDB4IAXgflWT4x1SxtfHHga0uL63hmk1WV1hkmVWYGzuEBCk5OWdVHuwHU10mr6LYa7aLb6lCzqjb43jkaOSNsEbkdCGU4JGQR1oGcRqk+j+FtK1TStYhubazs5U1C2ubGaSWVfMkbaxZslGDKc7js2nnjIo+HkuoazrV3qd7Jc3cNmDbRXGo3kMswLqkhCpboIlUqVywZiSMcYrs9G8PadoMMiafFJulx5s087zyyY6bpJCWOMnGTxmiz8O6Rp+qS6hp9hFaXMwIlaAGNZc45ZRhWPA5Iz7046P+v68hPU06KKKQBXm3/N03/cmf8At7XpNeYi7tz+1YYhcRGQeEPKKbxkP9r37ceu35senPSgD06iiigAooooAKKKKACiiigAooooAKKKKACiiigDL8Ttfp4T1VtGDHUBaSm2CD5vM2nbj3zXk2t6l4atIZrfwpa6XIl3pl3BdXVhff6QX+yyORdRCPk5TgvJvznjrXttFK17plKVmn2PDPEom0zTP7BvvMlhtPDWoSWlxLlhJbskOFZj1ZCCp9tp71p6lDoU1tfj4dR6fJpg0qRtQXRlQwmUSRGPIj+UybRL74/CvYKKvm1v6/r/AJ/eRb3VH+uhyOk6rp/iDx+1/oV7b6jZwaX5MlxayCSNZGlBCbhxuwCcdR36111FFTskv63uFtW+/wDlb9Cnq/8AyBL7/r3k/wDQTRpH/IEsf+veP/0EUav/AMgS+/695P8A0E0aR/yBLH/r3j/9BFAzH+I//JLPFf8A2Bbz/wBEPXSVW1LT7XV9Ku9N1CLzrS8heCePcV3o6lWGQQRkE8g5rz//AIZ8+GP/AELP/k/c/wDxygDsPF//ACJurf8AXq/8q2a8j8R/Aj4b2HhnULu08OeXPDbs8b/brg4IHBwZMVp/8M+fDH/oWf8Ayfuf/jlAHpNFebf8M+fDH/oWf/J+5/8AjlH/AAz58Mf+hZ/8n7n/AOOUAbHxRvrWw8FxyX1zDbRnVtNw80gQcXsLHk+iqzH2UntXYgggEHIPQivDviF8BfAVl4YjuNH024024/tCzhMsF3I5ZJbmOFgRIWHSQkYAOQO2QfaNM0+DSdJtNOswwt7OBIIgzZIRFCjJ78CgCzRRRQAVja//AMf2hf8AYSH/AKJlrZrG1/8A4/tC/wCwkP8A0TLQBs1zfij/AJGLwZ/2GpP/AE33ldJXN+KP+Ri8Gf8AYak/9N95QB0lZGo/8jNo3/bf/wBAFa9U9R0mz1VYhexuxhYtG0crxspIweVIPTtQBcorG/4RTSvS8/8ABhcf/F0f8IppXpef+DC4/wDi6ANmq2o3U1nYST21hcahKmNttbNGJHyQODIyrxnPLDgdzxWf/wAIppXpef8AgwuP/i6xfFnhQjw+zaBDqs14l1bOYrXVpYpZIRcRmZVZpVAJiEg+8OvUGgDm9I8O6DYXWi2V9oMnh7VnuHAu5bW2WbUlZJBIpe3ldlHzrlnYfMUAyTxm2elQt4j1HQdI0TxHY3cyWrgaheR3UdlGh2h9327ecbgf3bB0BXHDAHr7nw1faZo1+lxHqHiCaZltrE2rx+fZwIS8TlriVQ7q+CXzlsR5BwTUMOja7e+CTdC1vNL8TRSyTSSSCAvcO6gSCMJMyYKnbGHcYMcZbgZID11ZT02TSYk0Hw1pn2uaKPWXLakkaGE3aedcSRMrS+YNyozBtrLhl+Y5r0yuAs/D+n6lrGm/avBGv6YLOJY4bh9SijhhCRuqlo4Lo5ba7IG2E/NgkDp03/CKaV6Xn/gwuP8A4unf+v69BW1v/X9amzRWN/wimlel5/4MLj/4uj/hFNK9Lz/wYXH/AMXSGO07/kZtZ/7Yf+gGteuR0/wvpjeI9XQi8wvk4/0+f+4e+/mtX/hFNK9Lz/wYXH/xdAEmta0dPMVpYw/a9Uus/ZrUNgEDq7n+GNcjLe4ABJAPifwfv7jRPE/xjv7kLeXNlemaQRJsEzpJdE4GTgEjpk4r3LTtE0/SZZpbGArLPtEsskjSOwHQFmJOBk4Gccn1ryD4HqH+KPxaVgGU6yAQR1HnXVJ3a0GrJ6nbPe61olro+r3euyakmo3MEM9m0EKwoJeN0JVA42kg/Oz5UH61hXPifxBp2nXV5qGp39rdS2ty8Mc1pbyWTssTvGbeaNSf4QwErHcAeAa7mx8HaJp17HdWttNuhz5Ect3NLFb5GP3UTsUj4JHygcHFQDwD4dCyIbS4eF0dBbyX07wxB1Kt5cZcpH8rEZQAgE4pvW9vP+v+CEdGr+X9f8AyYjrdjqekafN4l1C9j1u3lBmlgtRNaOqBw8e2JVK9QQ6tyVq54GTVZ0vrrVfEN/qYivbm0SG4itkQLHKVVv3cSNuwvPOOTxWppHhTStEuPtFkl1JOI/KWW8vp7po04yqmV2Kg4GQMZwPStCx06102KWOyi8pZZnncbicu7FmPJ7kk46U7q9/63JS92z3/AOAWa5ux/wCSp67/ANgXTf8A0ffV0lc3Y/8AJU9d/wCwLpv/AKPvqQzpKKKKACvPfiQyfa45ksLi5bT7N7u4eC9EDLCsiNhFKMrtvjUgHbjb1r0KsDxD4L0bxRMsmrLeFliMJ+zX01uHQnJVhG6hhn1zRrdMOjKWlxST+Htdu9RsL/SZr4yPKdSkhdgvlgAjyWYBFAwB14JPXJ5bS4PDumXOkx+X4raRI7eWaV9WuvJtt7bIjLG0/wB12X7oVsD7wAr0DTvDdhpmk3GnRNeT21zu8wXl7NcsQy7SA0jMQMdgcVmW3gS0gXbNqeo3W64jmlMzpmZYv9VExCD5FODgYJPUnJy1ZSv6fgJ3a18/0KHji91Wx8RaW1npFxqumS6fex30YjaSCPMlsVkkjUEyEKJAqKCxy2MDcQeAfDq2F3c69Zal9v0zWtNsmtSA6CMKZ3xHG3McW2ZCqliQS2ccV0viK1S88OX8MklxEDCzB7a4kgkBX5hh4yGHIHQ8jIPBIql4O8O2Hh/QbWPTDeCN7aFRHcX89wkYVeAiyOwQc9FwOB6DCGUoPD9ivjKeAPe+VHZQyqh1CcgMZJAT9/0UflXNfG7X7HSfDMtn4hZRpWoQPAALWOaQyENzGGkGGUYIbbgHHNegX+g6fqV0Lm6jl84II98VxJESoJIB2MM8k9fWvOfir8EoPHml2Q0i/ksb6ydyhuppZo3V8bgdzEqflHI/H2AOl+GWvxeI/DIvNO+z/wBmKRHarb2yQKmM7l2K7YxxwQOvfNdRqWqafo9k15q99bWFqhAae6mWJFJOACzEDk1574A+C2neEPCi6bfalqdzdSSNLcPZapdWkTMQBgRxSKDwAMkZP0wBH8XPAvha++Ht0dZv59PS3cTQTTag23zQCFXErFTkEjHX0oA9OiljnhSWF1kjkUMjochgeQQe4p1cvofgrw/Y+H9PtdMlu57OG2jSCZdRmIkQKNrZVwpyOeABzxxV/wD4RTSvS8/8GFx/8XQBs0Vjf8IppXpef+DC4/8Ai6P+EU0r0vP/AAYXH/xdAGzRWN/wimlel5/4MLj/AOLo/wCEU0r0vP8AwYXH/wAXQBs0Vjf8IppXpef+DC4/+LooA2aKKKACiiigAooooAKKKKACiiigAooooAzfEPh7S/FWhXGja/a/a7C52+bD5jJu2sGHzKQRyoPBriP+GfPhj/0LP/k/c/8AxyvSaKAPNv8Ahnz4Y/8AQs/+T9z/APHKP+GfPhj/ANCz/wCT9z/8cr0migDzb/hnz4Y/9Cz/AOT9z/8AHKP+GfPhj/0LP/k/c/8AxyvSaKAPKLz9m34c3V9azwWF5ZxwNmS2gvXMdwMjhy+5gO3ysp5q9/wz58Mf+hZ/8n7n/wCOV6TRQB5t/wAM+fDH/oWf/J+5/wDjlH/DPnwx/wChZ/8AJ+5/+OV6TXNan4vGltr0c9iWm0uCOeCNZebtZAQgHHykyKUxz2PfFAHN/wDDPnwx/wChZ/8AJ+5/+OUf8M+fDH/oWf8Ayfuf/jld/wD2hEgaOdkS5jgE8kIbJVeec+mQRn2rjrX4iyy+EX125ttGWNnhjiEGsmVImkI/4+HMKiHbkZ4bv+J/X6AUf+GfPhj/ANCz/wCT9z/8cqj/AMM2/Dn+2vtv2C8+z7Nv9n/bX8nOPvZ/1mf+B49q6Kbx/PYy6JHqWkxr/ad8bNp7W986FBtBWVH2AupYheQpBz6c6egeLF17xLr2lxWbRR6RLHGtwZMi4LBtxAxwFZWXqckHpTs/6+X+aFdf1/Xkcx/wz58Mf+hZ/wDJ+5/+OUf8M+fDH/oWf/J+5/8Ajlek0Uhnm3/DPnwx/wChZ/8AJ+5/+OUf8M+fDH/oWf8Ayfuf/jlek0UAebf8M+fDH/oWf/J+5/8AjlH/AAz58Mf+hZ/8n7n/AOOV6TRQBzXw4GPhX4U/7A1n/wCiUrpa5v4cf8ks8Kf9gWz/APRCV0lABRRRQAUU2WWOCF5ZnWONFLO7nAUDqSewqL7dabrdftUOboZtx5g/fDG75f73HPHagCeiqWq61pehWq3Ot6lZ6dbs4QS3k6xIW64yxAzwePapLfU7C8GbS9t5/wB0k/7qVW/dtna/B+6cHB6HBoAs0Vlt4m0FLq0tn1vTlnvkD2sRu4w1wp6FBnLA+ozWpQAUUUUAFFFFAFPV/wDkCX3/AF7yf+gmjSP+QJY/9e8f/oIo1f8A5Al9/wBe8n/oJo0j/kCWP/XvH/6CKALlFFFAGN4v/wCRN1b/AK9X/lWzWN4v/wCRN1b/AK9X/lWzQAUUVBe31pptnJd6jdQ2ltEMyTTyBEQepY8CgDB8egN4btgwBB1nSgQe/wDxMLeulrwQ+GvC/iyZNTtdH0qBPFVw1tYSm0j221tGS0kuehupcsVU/MBjj5HrqPBVn4P8JXV/4lvP7I8Lm8K2NtaTyR2rQQoAyrKGIPnPkSMG+YAoD05APU6Kq2+qWF2tubW+tphdIZLcxzK3nIMZZcH5gMjkeoqaC5gulZraaOZUdo2MbhgrKcMpx3B4I7UASVja/wD8f2hf9hIf+iZa2axtf/4/tC/7CQ/9Ey0AbNc34o/5GLwZ/wBhqT/033ldJVTUdJ0/V4o4tUs4btIpPNjWZA2x8Fdwz0OGYZ9CaALdFY3/AAiHh7/oDWf/AH5FH/CIeHv+gNZ/9+RQBs0Vjf8ACIeHv+gNZ/8AfkUf8Ih4e/6A1n/35FAGzSMcKTgnA6Dqax/+EQ8Pf9Aaz/78ij/hEPD3/QGs/wDvyKAPOvCkGh3PiG3sTBoutNepMt60UQS9VSpbbfwksH6bcsR82MLzxn3Oh+HdI+H73aaJoESt4mlinN4kdtBJEt5IFSWTY2EAAAyCBgcV6r/wiHh7/oDWf/fkUf8ACIeHv+gNZ/8AfkU+1vL8Hcb1TXf/ACa/U8304pb+CdW1/QE061n0a/kuLIabL51h5bRoHiicKu5CM7sKMODxxXqGg6RHoeiwWUbtKy5eaZh800jHc7n3LEmq/wDwiHh7/oDWf/fkUf8ACIeHv+gNZ/8AfkUXJtqbNFY3/CIeHv8AoDWf/fkUf8Ih4e/6A1n/AN+RSGO07/kZtZ/7Yf8AoBrXqnp2j6dpIlGmWUFr5pBk8pAu4jgZq5QAV4l8Df8AkqfxZ/7DQ/8AR91XtteJfA3/AJKn8Wf+w0P/AEfdUAe20UUUAFFFFABXN2P/ACVPXf8AsC6b/wCj76ukrm7H/kqeu/8AYF03/wBH31AHSUUUUAFFQfbbXfOn2mHdbAGdfMGYgRkFvTjnmpIp4p7dJ4JUkhkUOkiMCrKRkEEcEY70APorJsfFXh7U0kfTde0y8WKRIpGt7yOQI7nCKcHgk8Adz0q1caxptpdLbXWo2kE7MiLFJOqsWfOwAE5y21sDvtOOlAC6pdRWelXM9xDLPEkZLxQxGRnHoFAJNeePqelfZPDv2HR9LhfWLEXax6jrL2qxA7MRqRG+9vn4GB9016JJdWlxcT6al3D9rEO94BIDIiNkBiucgEg898VzE/gi8Phuw0a01a1SGHTRpty1xpqytLHtClkO8FGOO5denynFNefl+t/xsP8Ar8v+CN8T6ZFomltfadolhdxQozz/AGvU57crjoECRybiemOO3XNZVjqWkHX73Sdc0AabNZaXHqEri9eVMkZkjzheU45756DFdZd+H5760tbS6vke2tr2K4VPIOXjjwUjYluTvAYt3xjHeszXPAS61rE1+dRaDzpoGdFhzuiRWWSInPRw3XtgdaX9f1/XQnXT+v6/4JkeDNQ0nxakfm+Hm092shdNG927lCZpYih6cjys598dsni/iZplr4l+GVle/wBgW0VtdiK4tvL1mRbnziG+VYzA6sApYklhwCeMV6HZfC7RRfG4122sNaUQtFFHeWCOIi08spI3bsf60Lx/dz3wKcHw41ezFpDb63pNxZ2mnCwhtr/RnmREx+8IC3CDL8A5BwAB65ejf9ef/AGtvu/Jfrc7PQNHtvD3h2w0ixVlt7G3SCMO+44UY5OBk/gPoK0KxV8H+Hwo36PYlsckQAAn6Uv/AAiHh7/oDWf/AH5FIDZorG/4RDw9/wBAaz/78ij/AIRDw9/0BrP/AL8igDZorG/4RDw9/wBAaz/78ij/AIRDw9/0BrP/AL8igDZorG/4RDw9/wBAaz/78iigDZooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK57XfCUet+ItK1N7poVsWzPAEyt0oYOgJzxtkVWB57jvXQ0UbNPsG6scw3gWz/wCEouNaS/1JZZoPLEZ1C4dFYliTsaQoV+biMrtGOlcu9tcWvxBg0CXW7ZdbudLE9vLb2HlQeTDJtWOWHzD5m7zJDwygbOAK9Pr5Z8S+O/J/a7s71Zs2thdR6WSTwqsuyT8mkc/hQtAep7X/AMK0EsEn2jUYY5ppJ5ZPsVl5EKvJCIw0ce9tmCofknLZ6Vs+GPCf/COXE8xvftUlxbwxSsYthaRC5eTqfvNITjt6muiop3FZBRRRSGFFFFABVea/s7aTZcXcET4ztkkCnH0NWK858beGbfX/ABI2oXXhO11OLSIA6ebaI0uo3DcRxbyM+Sm4s2eMkf3SCAbPw41Gy/4Vn4Uh+2W/m/2PZr5fmruz5KDGM9a62vK/Dfwr06z8RWJutD06NdIYXk17HYxxm8vX+b92QMrDFn5VHGdv9w59UoAKKKKAEdFkjZHAZWBDA9xXnnhjS9attSnjbTd3/COW76fpf2uVoYrkO+4OHCscCJYl3BTzuFeiVHPPHbW8k87BI4kLux6AAZJoWj/r+u/3h0secNN4juNH0y88TxX+mTWt5O8c+kQNqEvIkQb4zACow2AQjgjklc1PZ32p6bqdxqXiLTL5rjVdHtYgLGxlnHnoZtysIw3l/wCsU/MQvJ54rH/Z88aP4u8P6+LqXdcQ6vNcBM/cjnYyKPpu8z/Ir1yh6pruC0PIIdM1XRNMj0+O01D7e1naQvYPpzXdlfNHEgz5yr+4IIK/M4A27sHPPr46DPBooqpS5ndiSsFFFFSMKKKKAKer/wDIEvv+veT/ANBNGkf8gSx/694//QRRq/8AyBL7/r3k/wDQTRpH/IEsf+veP/0EUAXKKKKAMbxf/wAibq3/AF6v/Ktmo7m2gvLWW2u4Y54JkKSRSoGV1IwQQeCD6Vz/APwrjwR/0Jvh/wD8FcH/AMTQB0lc14sSSK+0TUJLW4u7GxunluYreFpnXMTKjiNQWfax6AE85xxS/wDCuPBH/Qm+H/8AwVwf/E0f8K48Ef8AQm+H/wDwVwf/ABNAHCS6RqfirXoI9Q06SO3bVRdR6jBpU9kc/ZJQszJK7lWR1QZO3JAyORmXSbjVdP8AEf8Aa3iPR9ShK6zcCY2unzXAb/Q4oxIqxKxKMynBx7HkV23/AArjwR/0Jvh//wAFcH/xNH/CuPBH/Qm+H/8AwVwf/E07227W/L/ITV9/63/zOasornSdbtfENzp2oJpkl1fMkENlJLNAs3lbCYUUuAzRuxG3I3jIHOOp8F21xBotxJdQSW5u9QurqOOVdrhJJmZdynkEgg4PIzzzUf8AwrjwR/0Jvh//AMFcH/xNH/CuPBH/AEJvh/8A8FcH/wATRsrfId21bzv+f+Z0lcj438UaJ4e1Lw5Hrep29k8+o5jErYyBE6k+wBdRk8cirX/CuPBH/Qm+H/8AwVwf/E1j658FPAOvXFnLP4dtLM2km/bYRrbLMP7sgQDcOPr6Hk0gO8orm/8AhXHgj/oTfD//AIK4P/iaP+FceCP+hN8P/wDgrg/+JoA6Siub/wCFceCP+hN8P/8Agrg/+Jo/4Vx4I/6E3w//AOCuD/4mgDpKK5v/AIVx4I/6E3w//wCCuD/4mj/hXHgj/oTfD/8A4K4P/iaAOkorm/8AhXHgj/oTfD//AIK4P/iaP+FceCP+hN8P/wDgrg/+JoA6Siub/wCFceCP+hN8P/8Agrg/+Jo/4Vx4I/6E3w//AOCuD/4mgDpKK5v/AIVx4I/6E3w//wCCuD/4mj/hXHgj/oTfD/8A4K4P/iaAOkork28DfD1bmS3bwv4ZE8UfmyRHT7fcicjcRtyBweenFZd1pvwesZYY76z8D20k8ayxLNFZoZEb7rKCOQexHWgD0CiuJvvDfwt0y5t7fUtF8IWc91/x7xXFraxtN/ugjLfhVSaw+DltqDWFxaeBorxJPKa3kjs1kV842lTznPagD0GvEvgb/wAlT+LP/YaH/o+6r0n/AIVx4I/6E3w//wCCuD/4mvH/AIN+E/DmqfEn4nWup6Bpd5b2OrCO1iuLKORLdfOuRtQEEKMKowMdB6UAfQlFc3/wrjwR/wBCb4f/APBXB/8AE0f8K48Ef9Cb4f8A/BXB/wDE0AdJRXN/8K48Ef8AQm+H/wDwVwf/ABNH/CuPBH/Qm+H/APwVwf8AxNAHSVzdj/yVPXf+wLpv/o++o/4Vx4I/6E3w/wD+CuD/AOJrT0jw9ovh9ZV0HR7DTFmIMosrVIQ5GcZ2gZxk9fWgDRooooA4PxtpWoSa2i6TaTSw+ILcaZfyxA/uFD7hIxH3R5bTDPqUFW7ubxXF4qNlaaTaf2KtjIqPHevu4KgEKYQvmYyAhfBH8Qrsaw/G2uf8I14F1rWAwV7OzkkjLHAMm07B+LYFLpb1/EH/AF/XyRw8MWry+HVsrWPVr/TdLk0+Zft2mm2uFaGdWkjRNqmQBEBBAbJ4DNniv4p0W78Za5/aGnWN/HbS3FokEtxZywOkkMd0wkKOqsqh5I+SACa2PgRr39v/AAd0aSSTfNZq1nL6gxnC/wDjmz869Eq3Jv77/PT/ACBafdY898E2moXPja98R6npt1ZS6rYKWSeNlMQSQqkZz0O0bsf7VehUUVPRIXVsKKKKBhRRRQAUUUUAFFFFABRRRQAUUUUAFFc3/wALH8Ef9Dl4f/8ABpB/8VR/wsfwR/0OXh//AMGkH/xVAHSUVHbXMF5axXVnNHPbzIJIpYnDJIpGQykcEEHIIqSgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAr5U1j9njxNe+PljufEOnte6ol1qRmCSYUxyxBh06kzjH0NfVdc/dRCT4k6XN5gDQ6TeKE7tvmtTn8PL/WgDbtVmSzhW7ZXnWNRKyDhmxyR7ZqWiigAooooAKo63qkWh6DfapcKzxWcDzsq9WCgnA/Kr1Q3tnBqFjPZ3kYlt7iNopY26MrDBH5UnsNWvqcPqHjHVtDF1FqWpeHZ7/wDs6a7j06FjFPbskZdQyNKWmU7SCyqnTOPSpffEfVINBSZbS0h1KLTbya8gkDOsVxCsbKBhgSjCTd6kEcjmtu7+HlvqMUcWq69rN9FCsqQJLJCBCskTxEDbEC3yucF9xyBz1zJrHw80fWbx7qeW7hmk0yTTHaCRRujcAbiCpG8Y4PvyDxitL67f8P8A8D/MI6Wv8/w/4Jnap4p1/wANJLBq0mm31xLZNd2s1taSQINkkaOjoZXJ/wBaCCGHfiulOqzjxkmk7Y/IawNyWwd24SBcZzjGD6VQXwTazQ3K6zqWoaxLcWxtRPdmJGiiJBKoIo0UcgHOM5A54q7pHh0aZeyXt1qd9qt48QhFxe+UGSMHO0CNEXGec4yeMnijqvn+tv0Is7fd+l/1NiiiikUFcJ8atd/4R/4P69cqwWWe3+yR89TKQhx9AxP4V3dRXFrb3cXlXcEc8ec7JUDDP0NAHyd+y5r/APZ/xGu9Ill2x6pZtsQ/xSxncP8AxzzP8ivrauR+H+m2EWi3E8VlbpMmsaoqyLEoZQL+cAA4z04+lddQAUUUUAFFFFABRRRQBT1f/kCX3/XvJ/6CaqaTq2nDRbIG/tQRbx5BmX+6PetcgEEEZB6g1T/sjTf+gfa/9+F/woAP7X03/oIWv/f5f8aP7X03/oIWv/f5f8aP7I03/oH2v/fhf8KP7I03/oH2v/fhf8KAD+19N/6CFr/3+X/Gj+19N/6CFr/3+X/Gj+yNN/6B9r/34X/Cj+yNN/6B9r/34X/CgA/tfTf+gha/9/l/xo/tfTf+gha/9/l/xo/sjTf+gfa/9+F/wo/sjTf+gfa/9+F/woAP7X03/oIWv/f5f8aP7X03/oIWv/f5f8aP7I03/oH2v/fhf8KP7I03/oH2v/fhf8KAD+19N/6CFr/3+X/Gj+19N/6CFr/3+X/Gj+yNN/6B9r/34X/Cj+yNN/6B9r/34X/CgA/tfTf+gha/9/l/xo/tfTf+gha/9/l/xo/sjTf+gfa/9+F/wo/sjTf+gfa/9+F/woAP7X03/oIWv/f5f8aP7X03/oIWv/f5f8aP7I03/oH2v/fhf8KP7I03/oH2v/fhf8KAD+19N/6CFr/3+X/Gj+19N/6CFr/3+X/Gj+yNN/6B9r/34X/Cj+yNN/6B9r/34X/CgA/tfTf+gha/9/l/xo/tfTf+gha/9/l/xo/sjTf+gfa/9+F/wo/sjTf+gfa/9+F/woAP7X03/oIWv/f5f8aP7X03/oIWv/f5f8aP7I03/oH2v/fhf8KP7I03/oH2v/fhf8KAD+19N/6CFr/3+X/Gj+19N/6CFr/3+X/Gj+yNN/6B9r/34X/Cj+yNN/6B9r/34X/CgA/tfTf+gha/9/l/xo/tfTf+gha/9/l/xo/sjTf+gfa/9+F/wo/sjTf+gfa/9+F/woA8/wDiGF1/UbaHR2iaSxhaa7mM2xbuAn5rMNkAmTbz/d2jP3hUVxcX+pa1rl14f1PTtLs7vSbVVj1DT2kZztl+Rf3sYVlyAQQ2Mjj19F/sjTf+gfa/9+F/wo/sjTf+gfa/9+F/wpWvFx/r+v66h9pPt/X9f8A8lkvbWx02OO2lvrOa50e2thZy2Bv7e7CxYEcpVN0TAsync6jv647JL2FvHeiXUskESJo1xHMUlDRxSF4Ds3dM/K2PXBrqP7I03/oH2v8A34X/AAo/sjTf+gfa/wDfhf8ACr5ve5vX8b/5kqNoqP8AXT/IzdR183FwNL8NSQXWoyLueXO+KzQ/8tJMH67UzliOwDMPK/gHC1v8SPinDJPJcPHqyI00mN0hE1yNxwAMnrwBXtlvaW1oGFrbxQBzlhGgXcemTivGPgb/AMlT+LP/AGGh/wCj7qpKPbaKKKACiiigAooooAKKKKACvGv2ndc/s34VppqMvmareRxMp7xp+8JH/AlT869lqC6sbS9VReWsNwF5USxhsfTNAHzz+ydr2611/wAPyP8AceO9hT6jY5/SP86+ja5P4Z2NpB8NPDFxBawxTSaNab5EjAZswoTkjk811lABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB//Z)
Amennyiben a tápok rendben vannak, akkor a RESET áramkör (Q511 és környéke), illetve az IC 502 dolgait kellene kimérni.
Na meg a 15,7MHz-es quartz rezeg-e?
Hifista.
Kösz, egyelőre feladom, a helyén semmihez nem lehet hozzáférni, annyira be van építve.
A C475 egy szuper kapac. 0,33F, annak mi a szerepe ott? 1,77V ra van töltve......
Volt nálam egy jvc mini HIFi,.ami az égnek nem indult el, ha nem volt backup táp. Kiforrasztva pár perc pihi, majd kondi nélkül is indult. De alacsony táp volt a kondin, el nem indult volna. A 0V, meg a relatíve magas táp jó volt neki. Szedd ki, kis pihi, próba. Hátha..
Kiszedtem, de nem indul.....
Hali!
A Q511 kollektorán mit mérsz?
Ha nem férsz hozzá a CN501 9. pinen is mérheted, egy potenciál.
KN
Hi!
Azt mondod??
Nem értem, ha megvan a hálózat, megvan az 5V a tekercsen....
Csak megerősíteni tudom Bálint válaszának azt a részét, hogy memória kondi, viszont ott 5 Voltnak kellene lennie - hacsak nem kapott a készülék hálózati feszültséget napok óta.
Legalább egy hétig tartania kellene a feszültséget.
Ha 1,77 V akkor az csereérett alkatrész.
Hi!
Tehát ha hálózati delejt adok neki megvan a tekercsen az 5V, de kiépítve a panelt csak jóval kevesebbet mérek rajta, de nem ez miatt nem indul a tuti... Az a gondom hogy a hideg mérésekbe bezavar...
Én is azt tanácsolom, mint mindigéhes, vedd ki azt a kondit,
Meddig tart, és egy hibalehetőség ki lesz zárva.
szia: igazad van, általában 5V
Van néhány alkalmazás, ahol a processzor 3,3V, ott a minimum a 3V.
A memóriakondenzátorok általában C/5,5V a feliratuk szerint
A töltésük diódán keresztól történik, a proci tápról, így a töltés után 4,5-4,7V mérhető rajtuk
szia: memóriakondenzátor, de legalább 3 V kellene legyen
