we have a problem about ICOM ic-t7h so we would like recommended how to solve/ It can memory channel but after turn off and turn on memory channel disappear Add new comment Comments 2022, July 6 - 08:50 #496093 Mr._V. 8 years 6 months If power off or battery eject? If battery eject: internal battery need change. 0 2022, July 6 - 09:01 [Mr._V.: #496093] #496094 TonyStark 4 years 4 months**** Hello! The radio is IC15: X25080SI-2.7 stores memorized channels in Eeprom, there is no internal battery. Regards: Tony https://www.manualslib.com/download/695844/Icom-Ic-T7h.html Look at the Service Manual. 2 2022, July 6 - 08:03 #496091 TonyStark 4 years 4 months**** Hello Lek ! Download the user manual, you will find the storage of the channels in it. To be safe, reset the radio. Regards: Tony https://www.icomamerica.com/en/downloads/default.aspx?Category=76 2
Hello!
Regards: Tony
Hello Lek !
Regards: Tony
