ICOM ic-T7H / saved memory disappear after turn on power
we have a problem about ICOM ic-t7h so we would like recommended how to solve/ It can memory channel but after turn off and turn on memory channel disappear
Mr._V.
Mr._V. picture
If power off or battery eject?
If battery eject: internal battery need change.
TonyStark
TonyStark picture
Hello!
The radio is IC15: X25080SI-2.7 stores memorized channels in Eeprom, there is no internal battery.smiley
Regards: Tony
https://www.manualslib.com/download/695844/Icom-Ic-T7h.html
Look at the Service Manual.
TonyStark
TonyStark picture
Hello Lek !
Download the user manual, you will find the storage of the channels in it. To be safe, reset the radio.
Regards: Tony
https://www.icomamerica.com/en/downloads/default.aspx?Category=76
